plowhog
Elite Member
- Joined
- Dec 8, 2015
- Messages
- 4,054
- Location
- North. NV, North. CA
- Tractor
- Massey 1710 / 1758, Ventrac 4500Y / TD9
I am getting a 1950's vintage International TD-9 crawler back in operating form. Right now I can run it on gas then diesel, and I can operate it in forward and reverse.
Initially, with the engine at RPM, the control lever to raise the front blade did nothing except make a lot of chatter/vibration. Pull the lever, nothing happened except chatter/vibration. The system was a gallon low on hydraulic fluid so I fixed that. But still no change in operation.
A few days later I added a psi gauge. I heard a small gurgle gurgle when I removed the plug where the gauge now is installed. Now, when I pull the lever to operate the front blade, the blade does rise and I'm showing about 500psi pressure. It does rise slowly, but not too bad. When I release the lever or move into the blade down position, the pressure is at zero.
I don't know what is causing the buzzing/chatter when I operate the lever. Does anyone know about what operating pressure I should be seeing? 500psi seems low?
