TC29D Hydrostatic transmission is stuck in forward
   / TC29D Hydrostatic transmission is stuck in forward
apparently so. It is a friend of mines tractor that I was helping him with. It has a slight trouble occasionally with "creep" where when you stop it may barely "creep" in reverse. It probably has a slight amount of wear on the spool valve that this rod moves and someone tried to adjust it before to prevent this. He said it has always done this and that you have to "rock" the pedal to center this spool valve to make it stop.
   / TC29D Hydrostatic transmission is stuck in forward #22
You can adjust the creep by adjusting "item A" in the drawing provided earlier in this blog. Loosen the nut and adjust. No problem....
Kubota HB84 Hopper Broom (A53317)
Kubota HB84 Hopper...
2008 CAT 305C (A53317)
2014 Freightliner M2 106 Palfinger PK22002EH 6 Ton Knuckleboom Flatbed Truck (A55973)
2014 Freightliner...
1986 Betenbender 175 Ton 10 Ft Press Brake (A59213)
1986 Betenbender...
TANK MANIFOLD (A55745)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
