TC29 shifting
/ TC29 shifting #1
Anonymous Poster
Epic Contributor
Hello. About a month ago I bought a TC29 (manual shifting). When changing gears or changing ranges I almost always grind the gears, sometimes worse than others. This even happens when beginning from a complete stop. Can anyone offer any advice on changing gears/ranges on the TC29 without the grinding effect?
Thanx
Vernon Bush
/ TC29 shifting #2
If you're fully depressing the clutch pedal a couple of seconds before moving the shift lever, and you're still getting the grinding, it sounds as if you need a clutch adjustment.
Bird
/ TC29 shifting #3
Bird, that was my thought as well. To tell the truth, when I bought my TC29D, I didn't really look at the manuel trans. Could there be some type of linkage or springs that might cause a problem?
Ernie
/ TC29 shifting
You may want to check your owner's manual or with your dealer, I don't think the transmission is a syncronized transmission. If it is not, you will get the grinding your talking about (unfortunaetly) If it is a syncro transmission, the gears do continue to spin for a few seconds after the clutch is depressed especially at higher rpms.
Giyi-D39 QA Trencher (A60463)
Giyi-D39 QA...
Ingersoll Rand SD-116DX TF (A53317)
Ingersoll Rand...
2006 TRAIL KING ADVANTAGE PLUS RGN/DETACH TRAILER (A58375)
2006 TRAIL KING...
208316 (A58375)
208316 (A58375)
2018 Nissan Pathfinder SUV (A59231)
2018 Nissan...
TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
TOOTHED BUCKET FOR...
