TC25d v TC40D
   / TC25d v TC40D #1
BigFoot032257
Greenfield , PA
TC25D 2002
Are theses two tractors (Tc25d. Tc40d ) 2002 on the same frame if so are the tires the same size ? And whats the wt dif
   / TC25d v TC40D #4
No and No. The weight difference is dependent on wheel & tire equipment and any added ballast. Average shipping weight for the TC25 is 2206 lb. I can't find that figure for a TC40, but I'd put it at about 2650 or so. Differences in liquid ballast capacities would broaden the spread.
I don't use Tractordata.com as it has too many inaccuracies for my taste.
   / TC25d v TC40D #5
Would you please enlighten me in regards to what source you utilize that is more accurate? The website that I mentioned is what I have used for past references. I would truly appreciate the assistance. Thanks.
   / TC25d v TC40D #6
Nebraska tractor test results where applicable.
Manufacturer's data.
Data published in Intertec I&T repair manuals.
Some of Tractordata's info is accurate, some is garbage. As with anything, the trick is to sort out the grain from the chaff.
   / TC25d v TC40D
Thanks I thought the two had the same frame so the puckits of one could go on the other as with the tires too R4 ! :thumbsup:
   / TC25d v TC40D #10
2018 KOMATSU PC360LC-11 EXCAVATOR (A51246)
2018 KOMATSU...
5 Piece Combo Kit 20V Lithium-Ion Drill/Fan/Batteries (A51573)
5 Piece Combo Kit...
2014 KENWORTH T680 (A52472)
2014 KENWORTH T680...
JOHN DEERE 2032R LOT NUMBER 239 (A53084)
JOHN DEERE 2032R...
Kinkaid 1200 LS-PH Towable Hydroseeder (A51691)
Kinkaid 1200 LS-PH...
100 GAL FUEL TANK W/ PUMP TOOLBOX COMBO (A52472)
100 GAL FUEL TANK...
