TC25d v TC40D
   / TC25d v TC40D #1
BigFoot032257
Greenfield , PA
TC25D 2002
Are theses two tractors (Tc25d. Tc40d ) 2002 on the same frame if so are the tires the same size ? And whats the wt dif
   / TC25d v TC40D #4
No and No. The weight difference is dependent on wheel & tire equipment and any added ballast. Average shipping weight for the TC25 is 2206 lb. I can't find that figure for a TC40, but I'd put it at about 2650 or so. Differences in liquid ballast capacities would broaden the spread.
I don't use Tractordata.com as it has too many inaccuracies for my taste.
   / TC25d v TC40D #5
Would you please enlighten me in regards to what source you utilize that is more accurate? The website that I mentioned is what I have used for past references. I would truly appreciate the assistance. Thanks.
   / TC25d v TC40D #6
Nebraska tractor test results where applicable.
Manufacturer's data.
Data published in Intertec I&T repair manuals.
Some of Tractordata's info is accurate, some is garbage. As with anything, the trick is to sort out the grain from the chaff.
   / TC25d v TC40D
Thanks I thought the two had the same frame so the puckits of one could go on the other as with the tires too R4 ! :thumbsup:
   / TC25d v TC40D #10
2006 BIG TEX 16 T/A TRASH TRAILER (A52472)
2006 BIG TEX 16...
2012 LEDWELL & SONS ENTERPRISES, INC. 48 HYDRAULIC TAIL DROP DECK TRAILER (A52472)
2012 LEDWELL &...
100 GAL FUEL TANK (A52472)
100 GAL FUEL TANK...
2014 Ag Spray Schaben Sidedresser (A53472)
2014 Ag Spray...
2003 HEIL KILL TRAILER (A52472)
2003 HEIL KILL...
2005 International 4200 Texoma UC-301 Pier Drilling Truck (A52377)
2005 International...
