TC25d v TC40D
   / TC25d v TC40D #1
BigFoot032257
Greenfield , PA
TC25D 2002
Are theses two tractors (Tc25d. Tc40d ) 2002 on the same frame if so are the tires the same size ? And whats the wt dif
   / TC25d v TC40D #4
No and No. The weight difference is dependent on wheel & tire equipment and any added ballast. Average shipping weight for the TC25 is 2206 lb. I can't find that figure for a TC40, but I'd put it at about 2650 or so. Differences in liquid ballast capacities would broaden the spread.
I don't use Tractordata.com as it has too many inaccuracies for my taste.
   / TC25d v TC40D #5
Would you please enlighten me in regards to what source you utilize that is more accurate? The website that I mentioned is what I have used for past references. I would truly appreciate the assistance. Thanks.
   / TC25d v TC40D #6
Nebraska tractor test results where applicable.
Manufacturer's data.
Data published in Intertec I&T repair manuals.
Some of Tractordata's info is accurate, some is garbage. As with anything, the trick is to sort out the grain from the chaff.
   / TC25d v TC40D
Thanks I thought the two had the same frame so the puckits of one could go on the other as with the tires too R4 ! :thumbsup:
   / TC25d v TC40D #10
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
LOAD OUT INFORMATION LOT NUMBER 4 (A53084)
LOAD OUT...
2015 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A52576)
2015 FREIGHTLINER...
2020 Mathieu MC210 Azura Flex Street Sweeper (A51691)
2020 Mathieu MC210...
2019 MACK GR64F TANDEM AXLE CEMENT MIXER TRUCK (A52577)
2019 MACK GR64F...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
