Tankless ele. water heater.
/ Tankless ele. water heater. #21
Charolais,
A big issue with instant water heaters is that they can only raise the temperature of the water N number degrees for X amount of GPM. Gas instant heaters can raise the temperature more than electric for a given GPM. You need to figure out the temperature of the water supply to your house and then look at the specs on the water heater to see if it will raise the temp to what you need.
I know at my city house the water supply temp varies during the year. With our well I think the water is going to be 50-60 degrees year round. So to get 120 degrees I need an instant water heater to provide at least 60 degrees of heat. It was tough to do this with some instant electric heaters at decent GPM.
I *** THINK *** that dishwasers are supposed to run water at 140 degrees to kill the bad bugs. If the washer does not have a water temp booster the water won't be really cleaning the dishes.
Check the specs on the instant water heaters. They show this information. What we thought about doing was to use an instant water heater and if the water temps where not high enough we would put in a solar water heating system to boost the supply temps. Hopefully the electric heater would not be needed....
Instant water heaters seemed to be 700-800 dollars. Twice what an 80 gallon water heater costs. The water heater we bought cost the same to run as the 40 or 60 gallon heaters.... To put in solar water heating was about 2500-3500 dollars. I can buy lots of electric power for 2000-3000 dollars....
Later,
Dan
/ Tankless ele. water heater. #22
Dan, so you're saying we'd be in serious trouble trying to take hot showers with an instant water heater...since our incoming water is only 34F!
Jeez, another good idea bites the dust! /forums/images/graemlins/confused.gif
Pete
/ Tankless ele. water heater. #23
Boondox, they do make models that will do showers. With a lo-flow head you should have trouble finding a model that would work.
Ken
/ Tankless ele. water heater. #24
Pete,
It depends. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
If you are running electric it might be iffy. Gas has the "power" to really heat up the water more than electric and at higher GPM.
I have not looked into this in a few years so maybe they have improved the models. We where going to put one in but the issue with the water temps and as well as the extra dollars we just decided to put in an 80g high efficient water heater. Right now we are fine with two small daughters and us with a 40g water heater. In a few years that might change so we splurged on an 80g heater. The cost was higher to buy over a 40/60g but the operating costs where the same so we went with 80g.
One option on the electric water heater is to have one for each water value. Course that gets expensive. /forums/images/graemlins/grin.gif
Later,
Dan
/ Tankless ele. water heater. #25
Good point Dmccarty,
If one heater does not heat enough, you have to add another one downstream to boost the water temp on up. About 1,000 or better to get water hot enough for a dishwasher. Take a long time of efficiency gains to pay that back. Also you will have to run 2 runs of wire to the location and have 2 more breakers in your panel.
Ben
/ Tankless ele. water heater. #26
If you were concerned with hot water quantity, would not having a pair of 40 gallon heaters produce more hot water than an 80 gallon tank??? Seems you would have twice the recovery rate, for about the same initial price. What is the recovery rate of the 80? KennyV.
/ Tankless ele. water heater. #27
It would cost twice as much to operate, however a larger single tank costs almost no more to operate.
Ben
/ Tankless ele. water heater. #28
OK. I find the idea of a tankless water heater intriguing. If I were to include one in my new house, it would be LP gas, because I'm not going though another couple of weeks without hot water when the next storm hits.
But, let me throw a curve into this discussion. I'm also intrigued by the idea of installing the hot water plumbing in a loop with a low volume pump, so there is always hot water moving through the lines. While this journey obviously cools the water, which must be reheated when it returns to the water heater, it is also the epitome of luxury -- instant hot water at any tap at any time.
Anyone have any ideas about how such a loop would affect or be affected by a tankless water heater? The water returning to the water heater would only be a few degrees cooler than the water entering the loop, so the effort to reheat it would be a lot less than "new" water.
/ Tankless ele. water heater. #29
Don,
I’m familiar with a few systems like that … insulate both runs, supply and return. You will like it… If you plan ahead the additional plumbing is not a big expense, your return path, and pump can be ‘very’ small.
As to tankless. A commercial applications where a steady ‘quantity’ of high BTU input works well, domestic use it not that common, dose not work out as well… KennyV.
/ Tankless ele. water heater. #30
Don, I agree with Kenny. The recirculating pump would be triggering the "tankless" water heater to come on too often.
There is a down side to these high efficiency gas heaters. Since they don't send a lot of waste heat out the flue, on cool down they condense water out on the flue system (the high efficency "pulse" heating units have to have a water drain because of this). This can corrode the vent systems. And, on a system that cycles on and off a lot (like with a recirculating water system) there will be more water produced in the flue eating away the lifetime of the unit.
Recirculating hot water systems are how Hotels manage to have hot water quickly on tap in the rooms. So, it is a fairly common system, just not used in houses much.
/ Tankless ele. water heater. #31
What type of heater do you have in your house? Up here there are a lot of boilers and there is a water tank that hooks up to the boiler. The tank is called a Boilermate and you can get some more info from their site Boilermate website . Regular hot water tanks have a 6 year warranty, this tank has a lifetime warranty and by using the boiler for its heat source actually helps prolong the life of the boiler as it gets used year round instead of just during the winter. It runs of its own zone so when the tank calls for heat the boiler runs. Also, it is 99% efficient but it can only be as efficient as the boiler so if you have a 92% efficient boiler your hot water tank is the same which is much higher then standard hot water tanks which means you save money in the end. If this don't work for you then maybe someone else can use the info
/ Tankless ele. water heater. #32
Kenny,
What slowrev said as well as we only have space for one heater. Even it two would work money wise we ended up not having the space for two tanks.
Later,
Dan
/ Tankless ele. water heater. #33
Don,
The tankless heaters are triggered by flow I think and if this is true the water would just keep getting hotter in the loop untill something failed or an overheat safety tripped in the tankless heater. Or at least this is my thinking on what would happen with tankless heaters in a recirculating loop.
MIght go boom !!
Ben
Robert I'd sure like to have a system like that. I heat the house mainly with wood(stove is outside in a building but doesn't use water) but do use some LP for back up. Now I heat the hot water with the standard electric tank type water heater. Where I live the well water temp. is 63 deg. I just checked that last week. The dish washer we have has a heater built in it so that's not a problem.
I read the instructions with the tankless heater I ordered and it stated not to run preheated water in to the inlet.
I'm gonna give this tankless heater a try. If it doesn't work for me I have a plan for it. If it does work I still may add a small 30 gal. tank type heater. My PTO generator won't run the tankless model. To many amps. We sometimes get lots of sleet and freezing rain in my area and I want to be prepared for power outages too.
Thank you all for lots of ideas and a great discussion. The thinking caps and light bulbs are on. With enegery prices the way they are now it's time to start trimming where ever we can. I don't see those prices heading down any time soon.
In my area we just had the tobacco quota buyout bill pass. Many tobacco farmers won't continue growing now. There are lots of bulk barns that use wood fired heaters(boilers) with the hot water system. I'm gonna keep my eye on those when the auctions start. I may be able to get one at a good price then. There's going to be lots of sales like that next year in this area.
/ Tankless ele. water heater. #35
Is there any reason you can't use a propane tankless heater? We have one in that was already in the house when we bought it two years ago. It is really great and satisifies all our hot water needs, and doesn't require any electricity. It is made by Paloma. Our primary heat is propane though we have a wood stove that we burn as much as possible. Even with propane prices up as high as they are now it's still cheaper than electric. I would certainly check into a propane unit as long as you are looking. It would save you the additional expense/labor/space of hooking up a backup tank.
1995 John Deere 5200 45HP 4x4 Utility Tractor (A61572)
1995 John Deere...
Timpte 720 All Aluminum 7000 Tilt Trailer (A63689)
Timpte 720 All...
2004 BMW 325ci Convertible Coupe (A62613)
2004 BMW 325ci...
2025 JMR 72in. Hydraulic Dual Cylinder Brush Grapple Skid Steer Attachment (A61572)
2025 JMR 72in...
2024 John Deere 6R 145 Tractor (A63111)
2024 John Deere 6R...
John Deere Gator TX4x2 (A62177)
John Deere Gator...
