Tandem Disc Harrows
/ Tandem Disc Harrows #21
sunspot said:
A bit of an update. I was looking to make the trip up north to look over the disc harrows and I find this notice on the web page.:eek:
"For Wholesale Dealers only at this location!"
See the link below.
Lowey
Sorry, I guess their dealers were complaining about everyone going straight to them to buy implements. I bought my disk back in October or Early November. I hope I can still go there to buy parts, as they have really good deals on parts.
Chris
I may go there anyway. That way I can see the different models to do a comparison. If I have to go to a reseller afterwards, so be it.
/ Tandem Disc Harrows #23
http://i204.photobucket.com/albums/bb25/Bigboy1mf/mf254.jpg
Here's my favorite type of 3-point mounted disc. Massey Ferguson #25. They were made from late 50's through late 80's. Adjustable gangs from operators seat, and enough built-in weight to get the job done. They are the best mounted disc I've ever used. Great leveling action too.
/ Tandem Disc Harrows #24
You're right, these are very good. Yours in the picture is nice because it has the wider frame. They level pretty good because the gangs kind of float on ball joints and the back has some float independent of the front. Also I believe ths spacings were 6.5", which makes a nice seedbed. For anyone working plowed ground for a seedbed I would say stay away from 9" spacing, try to go with 7-7.5" front and back if that's what's available.
QUESTION ABOUT THE MODEL #25: What do you do when the white metal bearings are worn out? After they wear to a point the blades will rub on the frame. I would like to fix mine up but the last time I looked the parts were astronomically priced, you could buy a decent new disk for the price of the bearing parts. I used to know a place that cast the bearing parts, but no more. From Agco each bearing piece might be running close to $100.
Any ideas?
/ Tandem Disc Harrows #25
I've got a 6 1/2' Howse. I don't care much for their mowers, but the disc has performed and held up well and weighs 850 lbs or 42.5 lbs per blade. To get it to cut and break really well the rear gangs have to be set at the max angle. It's been good for me for gardens and deer patches.
And a little 2,4D on those gum trees will take them out.
N80 said:
Well, it just so happens that I stopped by a tractor dealership on my way home from work and they had a TH series 8' disk with 22" notched blades with 9" spacing, tubular gang hangers and beefy pillow block bearings. It weighs over 1100 pounds in that configuration and the dealer had it priced at around $1700.
You got a very good price:D . I was quoted $3,150 for a TL and $2,000 for a TH that is smaller and lighter than the one you bought. Tufline may be a very good brand but it's not in my budget
/ Tandem Disc Harrows #27
I by chance found a nice looking offset disk here:
http://www.unverferth.com/ustmax.php
I expect it's pricey, but it certainly looks heavy duty and has some nice features. The 6' model weighs in at 1805 pounds.
I've got a KK 6' that has been satisfactory for my needs, but if I had the money and HP I think I'd take a look at the Maximus disk.
/ Tandem Disc Harrows #28
Any ideas?
Hmmm. My first instict would be to find another disc that could be bought CHEAP as a parts donor. Maybe one with a broken frame/worn out disc blades/ect. They appear in dealer back lots and at auctions quite a bit. The boxings have to be absolutely trashed before they're worn to the point you have to give up on them.
I've been able to find a few #25's at auctions, in GOOD condition, for under $400. I bought a junker 3 years ago for $110. I got a complete set of scrapers, 3 good axles, 5 of 8 bearings in good condition, and 400lbs of scrap iron out of the deal.
Then there's the "poor people have poor ways" method. ;) I saw my dad split bearing, wrap the spools in leather strips, re-assemble, grease, and run them several more years on a couple occasions.
The #25 in my picture has 7-1/4" spools. You're correct about their ability to allow each gang to float independently. There is also a way to "lock" each gang so that it becomes a rigid frame too. The picture WAS an 8'-10" model at one point. (as pictured) I cut down the axles, removed one blade and one spool from each gang to end up with a 7'-6" version. Much easier to haul with it now being under "legal width".
It's sitting in front of the shop door now too. Sometime in the next week or so, it gets the royal treatment. Dsimantle, sandblast, prime, paint, and decal.
/ Tandem Disc Harrows #29
Farmwithjunk said:
Boxings will remain servicable long after wear becomes evident. For a disc that'll see ocassional use, I personally would prefer the boxings. The deal with wear/dirt/water/rust/abuse in a much more forgiving manner.
Like this?
Rob
/ Tandem Disc Harrows #30
As a point of interest, just last week, I walked through the National Farm Machinery Show in Louisville Kentucky. Woods had a nice display. In addition to their standard line of mowers and such, they had on display a new product in their line. A heavy duty 3-point disc. It looked to be VERY well made. Plenty of built in weight. Comparing it to the majority of 3-point disc's available these days, I'd rate it about a 8 (out of 1-10) No price info.
/ Tandem Disc Harrows #31
You may have seen my brother at the Kuhn booth.
/ Tandem Disc Harrows #32
Might have! I sat on a piece of their equipment and ate my lunch by coincidence! More than 200,000 people each day walk through that show. Ask him if he remebers an old guy in bib overalls and a camo hat ;)
Unverferth Maximus Disk
I must say, that's a different looking disc. It is very heavy for the size. I'll call them for the heck of it.
/ Tandem Disc Harrows #34
Well thought out. Loads of adjustments, fenders to keep the dirt splash down, and even the tooth on the middle where the disk misses. Pricey I'm sure!!
/ Tandem Disc Harrows #35
Here are some disks made in Texas, Hay King brand. Anyone know anything about them?
K&M Mfg. Product 5
The Monroe Tuffline is probably a good disk, but I saw one at a local dealer, it had only been there a few weeks outside and the paint was peeling off to bare metal.
Farmwithjunk: I saw a Model 25 at an auction a few years back, it was all there but had been burnt up in a fire. Two guys bid like madmen on it, I think it went for either $400 or $600. The auctioneer even joked that they paid more for the burnt up disk than two good 3-pt 10 footers he sold right before, a JD and a MF.
I run my disk 50-100 hours a year and since the ground is sandy loam it seems to do a job on the bearings. I grease every 4 hours. Put more grease in that little disk and a Ford 201 disk than anything on the farm. The Ford 201's are very good disks also.
I gave them a call. You have to buy from a dealer and they are only in TX. I was given a retail price of $1,600 for the DM2020.
Pricey? You bet. The 7' model is $4,995.:eek:
Seeing the weight on those things, they may well be a great disc but my wallet won't let me find out about them.
/ Tandem Disc Harrows #38
Speaking of discs and grey iron bearings.. who remembers wood bearing halves?
I've got an old ford disc witht he grey iron.. just got to keep the grease going to them..
soundguy
/ Tandem Disc Harrows #39
soundguy
I've got about 50% of a 6' Ford disc laying in the scrap pile that has wooded bearings. They held up better than the frame. I dragged it here a few years ago when we cleaned out my uncles barn. It spent the better part of 10 years with a bunch of ammonium nitrate bags piled on top of it. Talk about rust.
/ Tandem Disc Harrows #40
Good gosh! Even if I could afford it, my little tractor would sit and spin trying to pull 1800 pounds of disk in soft sandy loam.
Thanks for looking up the price. I guess my 6' KK was a better deal than I thought at $250.
INTERNATIONAL 5300 END WHEEL GRAIN DRILL (A64278)
INTERNATIONAL 5300...
Pemberton Inc 416469 72in. Loader Forks and Frame (A64194)
Pemberton Inc...
2007 Toyota Rav4 (A64557)
2007 Toyota Rav4...
Year: 2014 Make: Chevrolet Model: Equinox Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 134,356 (A64557)
Year: 2014 Make...
2020 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A67148)
2020 KENWORTH T680...
2017 Toro GrandStand 52in Stand-On Mower (A64553)
2017 Toro...
