Taking the Welder Plunge
/ Taking the Welder Plunge #21
Kratos said:
I have also found 15 year old Linclon 225 AC for $100. What say ye all?
You absolutely will not go wrong with that. Go for it. I know I would in MY condition. I am looking for something better than the < $100 newer machine I have. Just cannot find anything used here.
Mike
/ Taking the Welder Plunge #22
Kratos said:
Hobart seems to adjust how long you can weld based on amperage used.
It's simpler than that. Like Tom said. At low output it will shed heat as fast as it generates internal heat. At higher output it can't shed heat fast enough so you have to let it cool.
That's all it means.
/ Taking the Welder Plunge #23
Hey California......
I had a Monkey Wards AC stick welder too. It was great! I used it like crazy until a guy gave me the Miller. Mine had a knob on the side that you tightened down after you adjusted a joy stick for the amps. The case on mine was so rusty when I got it that I couldn't read what setting I had it on. I gave it to the road comish and he uses it to patch up grader blades etc.
/ Taking the Welder Plunge #24
bigdad said:
Hey California......I had a Monkey Wards AC stick welder too. It was great! I gave it to the road comish and he uses it to patch up grader blades etc.
Look something like this? http://www.tractorbynet.com/forums/related-topics/52820-wards-powr-kraft-230amp-stick.html
Hey Kratos! did you hear that? If you run out of projects you can weld up grader blades for the County with your hundred dollar welder! Try that with a little wire welder!
As that thread I referenced shows, I'm simply a couple of years in the lead on the identical path as you. Now, with some experience, I have verified that a 225 amp ac welder does everything I need. Cept I prefer 'Aspiring Gentleman Farmer', to your "wanabe "Green Acres" style mini-farmer". :D
Here's my latest repair weld. The pivot pin on one side of the garage door tore out of the arm. I welded it back in, stronger than the original mushroomed-head type of connection. Good for a second 60 years. Without a welder I would have needed a whole new garage door assembly since this style is no longer made.
I am meeting the guy at his house at 4 pm tomorrow to pick up the $100 Lincoln 225 AC. He says that he has found lots of rod, gloves, and a chipping hammer that he is throwing in. I am stopping by Harbor Freight on the way back to pick up a self-darkening helmet like some of you guys mentioned with some of the money I saved.
Thanks for all of the advice.
/ Taking the Welder Plunge #27
Great!
One more word of advice: The HF self-darkening helmet works great. However - I wear bifocals and it was torture to shove my glasses up high then hold my head just right to watch the weld through the magnified lower half of the bifocals. I tried tying the lenses from a headband magnifier into the helmet but that didn't help, because I need the prescribed astigmatism correction as well as magnification. HF has just announced a large-window version of the self darkening helmet. I'm going to get one, and for anyone wearing bifocals I recommend that one.
/ Taking the Welder Plunge #28
California said:
Great!
Another possible solution for those with vision correction needs are the diopter lenses available for the standard welding helmet opening. They fit, with sometimes a considerable difficulty, behind or between the shaded and the clear protective lenses already installed and are available in most standard corrective magnifications.
/ Taking the Welder Plunge #29
Don't forget the local "Dollar store" for those reading glasses to wear under the helmet. My local store has a bunch, and I find them useful as spare pair to read my computer screen. I have perscription glases, but sometimes misplace them so spares come in handy.
I also have pretty severe astigmatism but eyes seem to adjust to whichever glases I wear, the cheap set of glasses work fine, just get a swimming sensation when I swing my head around quickly.
/ Taking the Welder Plunge #30
Yep that 100 dollar lincoln will do you right. Don't worry if it's rusty or dented a little. Like someone else said, they just seem to run forever.
I would like to say something about flux core wire feed welders. With a good quality machine, they do not make lower quality welds and actually give better penetration than ar/co2 sheilded, and are not disrupted by breezes.
I am trusting that a good name and less bells and whistles will last me longer and not give me any trouble. I have to drive right past Harbor freight to get to the guys house to pick up this 15 year old $100 Lincoln 225 AC and this sure looks like a good deal, but you have to ask how they have enough supply of reconditioned welders like this to advertise on the internet this price. They must have a lot of them sent back broken.
Harbor Freight Tools - Quality Tools at the Lowest Prices
/ Taking the Welder Plunge #32
A 225 Lincoln stick welder in good operating condition for $100 is almost impossible to beat for welding 3/16 and up material. It's going to weld solid and you're not going to have the weld and wait, weld and wait duty cycle issues that you'd have with a small mig.
/ Taking the Welder Plunge #33
For a savings of $10.01 that HF welder is less than half the welder that the Lincoln is.
It weighs half as much, which is a simple description for the quality of transformer in it. It draws maximum 20 amps from your dryer outlet while the Lincoln maxes out at 50 amp draw. At 130 amp output, which would be normal for much work with 1/8 rod, the duty cycle is 10% which means you weld for 60 seconds then it has to cool off for NINE MINUTES before you can do another 60 seconds. And the large number of customer returns means many people bought one and were disappointed.
I expect it would be fine for welding light materials but I think you need a welder that can run 1/8" rod - and that one won't, realistically, if they rate it as 10% duty cycle. You can afford the $10!
I just came back from picking up my new (used) Lincoln welder. My wife also noticed a plug by the front door of my garage that looks like what a stove or dryer would plug into. I am hoping that it is a 220 outlet with enough power to run the welder. Of course, I have two questions.
(1) The plug has a round hole on the bottom and two vertical straight holes up top parrallel to each other and one longer than the other. Does this sound like what I need and how can I test it. All I have is a cheap voltage tester that I don't suppose could handle high voltage.
(2) The plug on my Lincoln 225 AC has a bottom male plug that is a 90 degree angle and two top ones at an angle from each other. If my outlet is 220 volts with enough amps, can I get an adapter to make the two plugs fit or do I have to have either the welder or the outlet redone?
Thanks for the continued help getting me started.
John
/ Taking the Welder Plunge #35
If the receptacle on the wall is about 50% larger than a 110 outlet, id should be 220v, but checking it would be a good thing.
If it is a 220 outlet, either buy a new plug to match the receptacle on the wall, or buy a new receptacle to match your plug.
/ Taking the Welder Plunge #36
It sounds like somebody put a clothes dryer cord on your welder to match the outlet in his garage.
Maybe the previous resident of your home had a welder. That outlet is for the plug that was original on many welders.
The cheapest solution would be to replace the socket in the wall to match your welder. Dryer stuff is common and inexpensive, while the original-type welder plug is $12-15 just for the plug and may be hard to find. Get somebody who knows how to do this stuff to change the socket, or to replace the welder plug if there isn't space in the wall for a dryer outlet.
I made an adapter for a mismatch that is opposite to what you have. I had a spare 'pigtail' (plug/cable assembly intended for a dryer) so I put an outlet on the other end of it to match my welder.
Added: I put '50 amp welder outlet' into Google and found several explanations. The Welder's Handbook excerpt is useful - both the page that Google hits on, and also its adjacent pages that you find there.
I was thinking that the best fix that would add versatilty to my welder would be to construct an extension chord with a male plug that would fit the receptacle in my garage and a femaile receptacle that would fit my welder and 25 ft. of the right cable. Since this welder has wheels, but the standard short electrode and ground cable, this would give me the ability to get to my work without extending the other two cables.
Does anyone see a problem with this? Does anyone know if both types of plugs are just three wires with two hots and a ground or neutral?
/ Taking the Welder Plunge #38
Kratos, You are right--two hot and common or ground. Looks like you got a cream puff of a welder. Many happy hours in the garage making things and fixing things with that. Good for you.
Mike
/ Taking the Welder Plunge #39
Was that the $100 unit I pointed out to you on Craig's list? I'd have jumped on that myself except I'm 1500 miles away. Nothing that good showing up on Craig's list here.
No, not that one, but another that you gave the link to. The $100 one was all the way in Samammish which would require me to go through Seattle traffic and the kid who has it, really knew nothing about how old or what condition it was in.
The one I bought had a picture and was listed for $175. This guy took the lower amount I was offering and threw in gloves, rods, and a slag hammer. He was an older guy who had it 10 years and only used it a few times and takes real good care of his stuff. He never mentioned the plug being changed, but after 10 years probably forgot.
I picked up a self-darkening helmet from Harbor Freight on the way home which was on sale for $49.00 with a 15% off coupon I had, I paid about $42. So all set other than being able to plug it in and learning how to weld. LOL
Here is a link that a guy on the welder forum gave http://frentzandsons.com/Hardware ...nfiguratio.htm
and shows the receptacle in the garage as 50A 2-pole, 3-wire grounding and the plug on my welder as 30A 3-pole, 3-wire. So not sure if the extension chord deal will be so easy. I guess this is why people make a living as electricians.
