Tajfun Logging Winch, clutch Adj.?
/ Tajfun Logging Winch, clutch Adj.? #1
sparkkky
Oklahoma
Kubota B21
Hello, can anyone give me any pointers on this?
/ Tajfun Logging Winch, clutch Adj.? #2
Can you contact the company, a dealer or USA importer via email? I did some research on this brand last winter and located a dealer in Marshfield, WI, about 160 miles away. My tractor folder is out at the camp, so don't have info on who I contacted. If you haven't done a Google search, it may be worth a try.
penokee /forums/images/graemlins/smile.gif
Ps: Did you consider a Farmi? I haven't purchase yet, but have it boiled down to Farmi or Typhoon. What helped you in picking a brand? Thanks. /forums/images/graemlins/smile.gif
/ Tajfun Logging Winch, clutch Adj.? #3
Try this page
However, if you do a google search you will find a lot more pages about that winch.
Hope this helps.
murph
Been talking to Anders, the man I bought the winch from, and he is suppose to confirm what the manual is saying. If you turn it the wrong way you have to pull the drum.
Yes, I would buy a Tajfun again!
/ Tajfun Logging Winch, clutch Adj.? #5
My manual says to move the adjusting nut to the right for more tension. Only by turning it to the left could you loosen it to the point of having problems with the clutch plates.
Is the clutch slipping? I have pulled 10 cords of hardwood firewood and around 2600 bdf of logs plus some other pulling chores and it is still pulling strong.
I did have to make a small adjustment on the brake power about half way through the logging described above. The manual was right on for that adjustment.
Let us know how you make out
Dave
Looks like the set screw came loose and it backed itself off. Seems like I am good to go now!
/ Tajfun Logging Winch, clutch Adj.? #8
Great Sparkky, the simple fixes are the best /forums/images/graemlins/grin.gif
Dave
2014 Ford F-150 4x4 Ext Cab Pickup Truck (A64194)
2014 Ford F-150...
Bobcat Skidsteer Snowplow
Bobcat Skidsteer...
2003 McCormick XTX 185 XtraSpeed Tractor (A63118)
2003 McCormick XTX...
(2) 1500 Gallon Tanks w/ Pump (A64047)
(2) 1500 Gallon...
2013 FORD F250 (A60460)
2013 FORD F250...
2019 RoGator RG1300C Spreader (A63109)
2019 RoGator...
