T7074
/ T7074 #1
chh
Eastern OK
MF 596 , MF 4243, MF 1433V, D4H, D3C
I did a search on them in this forum and didn't find much. Does anyone have any recent feedback on them? I know there is a larger model coming out with more hp and am thinking about waiting for them. but I was talking to a dealer today and he has a new 07' T7074 with cab/air and loader that he is really trying to make a deal out of. He has it priced cheaper than a MF573 2 wd and loader and the Montana seems to be a much nicer machine. It would be mainly a tractor for my wife to mow hay with and to rake with. It would be used with my 2 MF's in our hay and cattle operation. I have never really considered a Monatana before, but some nieghbors have this same model that they use with a batwing brushhog and generally abuse the heck out of and it is holding up well.
Any info appreciated.
/ T7074 #2
No first hand knowledge, but there is one guy around here that has one that he uses with his cattle operation. I had looked at his at the dealer before they delivered it and it sure looked like a nice tractor to me. If the price is right, you might want to jump on it before the opportunity is gone. Remember, if you snooze, you loose.
Good luck
/ T7074
Well I gave the wife a choice between a new MF 573 with MFWD and a loader later or the new '07 Montana set up with ag tires, MFWD, FEL, bucket and Hay forks for less money. She was more comfortable in the Montana and picked it if the dealer would change the stereo with a tape deck for one with a CD player.;) He offered what I thought was top dollar trade in on our MF 1433v(I don't need 4 tractors) and I agreed to pay cash for the difference. I've only averaged about 25 hours a year on the 1433 for the last 3 years. The new tractor used in our current operation should get used considerably more and I can pick up a cheap riding mower to take the place of the 1433. I guess we shall see if it is a good choice or not.
/ T7074 #4
Please let us know how she likes or dis-likes the new Montana.
Good luck with the new purchase. :D
/ T7074
Here are some pics of it. The first couple are as it was delivered. I took the loader off to while we are using it to mow with. The wife likes it very well. It is an easy tractor to use and rides pretty good.
/ T7074 #6
Looks good. Hope that both of you like it and that the 7074 works out good for you guys. ;)
/ T7074 #7
FYI, the T7074 is manufactured by TYM, see TYM 700. Powered by John Deere engines.
/ T7074
It is well know that it is a Tym made tractor and it has tags labeling it as such. I did not find anything negative in a T700 search either. I am trying to not hold the fact that it is green and has a JD engine in it against it.
/ T7074 #9
CHH, Looks good what size mower you pulling with the tractor?
/ T7074
It is a 9' Krone AM 283 S.
/ T7074 #11
I see you have the loader off the 5455 too. Any reason why you don't leave them on to mow? Did you feel that either machine was too light with the Krone and no loader or weights?
/ T7074
Taking the loaders off is a personal preference. I do not like the extra stress the loader puts on the front end running around the hayfield. Plus they just bounce and cut down on visiblity. Any of the 3 loaders I have can be on or off in 2 minutes or so. I used to have a Ford 4600 SU series loader tractor with non quick detach loader on it. I finally took the loader off and left it off after I got another tractor with a FEL. I broke the front end down 3 or 4 times on it. I remounted just before I sold it. The 5455 will not get light at all with the mower on. The T7074 and the MF 4243 are Ok for field use, but not safe to load on a gooseneck trailer IMO. I have not tried loading the Montana yet with the mower on, but I did test it by facing it up a small, but steep hill and letting it roll back and stepping on one brake at a time. You could make the front end slide sideways fairly easily. The MF 4243 I have hauled, the only safe way to load it is backwards. I learned that one from experience.
/ T7074 #13
Good info, thanks. Thanks for the pics too.
2012 Ford F-450 4X4 Dually Truck, VIN # 1FT8W4DTXCEB64960 (A65563)
2012 Ford F-450...
New/Unused 76in Pallet Fork Extensions (A65583)
New/Unused 76in...
KUBOTA KX033-4 EXCAVATOR (A64279)
KUBOTA KX033-4...
(3) Pieces of Poly Pipe (A62679)
(3) Pieces of Poly...
2014 FREIGHTLINER CASCADIA (A65643)
2014 FREIGHTLINER...
John Deere 660 Hay Rake (A65640)
John Deere 660 Hay...
