T574 Seat Cushion Replacement?
   / T574 Seat Cushion Replacement? #1
Suburban Plowboy
FL
Kubota L3710
I am looking at a TYM T574. The lower seat cushion has to be replaced. I have not found it online. The entire seat costs $1270, and people say TYM's seats are not great.
Is there a good aftermarket seat cusion that will fit? I don't think TYM offers the cushion by itself.
   / T574 Seat Cushion Replacement? #2
Mine has a seat cover on it.
I wonder if it will come apart so an upholstery shop can fix it.
   / T574 Seat Cushion Replacement? #4
I’d take a look at Vevor aftermarket seats, have two of them and they work great. Around $250-350 and are adjustable with suspension and arm rests.
Thanks. A dealer just got back to me, and TYM does not sell seat cushions. Unbelievable. A tractor is supposed to go 4,000 hours in hard conditions, but the seat falls apart at 500, and you're supposed to pay $1300 every time it fails.
   / T574 Seat Cushion Replacement? #6
Have you seen the seats they put in the TYM made Badboy tractors? they look nice, I would investigate how much one of those are and just upgrade.
I just saw a $1400 Bad Boy seat on the web.
I guess this is one of the ways in which tractor manufacturers make money on the sly. They design seats to fail and then refuse to sell parts.
   / T574 Seat Cushion Replacement? #8
The seat on my T233 was bad. I pulled the seat and went to tractor supply, and bought a generic replacement with the same mounting bolt pattern. Works great, the only issue is that it is just enough wider than the stock seat, that the seat belt is difficult to latch. Other than that no issues.
2015 CATERPILLAR  XQ30 GENERATOR (A58214)
2015 CATERPILLAR...
DRAGON 500 BBL ACID TANK (A58214)
DRAGON 500 BBL...
Land Pride FDR1660 (A53317)
Land Pride FDR1660...
2019 CATERPILLAR D6 HIGH TRACK CRAWLER DOZER (A60429)
2019 CATERPILLAR...
2014 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2014 Ford F-150...
2019 Ram 1500 Crew Cab Pickup Truck (A59230)
2019 Ram 1500 Crew...
