T293 4WD?
/ T293 4WD? #1
MarkSorrells
TYM 293
Hi,
Has anyone else out there had trouble getting their new tractor into 4WV. I feel like I'm about to break the shift lever to get it to ingage......
Thanks,
Mark Sorrells
/ T293 4WD? #2
Might want to try to move it a little bit forward if it seems hard engaging, it should be easy to move the lever. I know my T330 gear tranny is that way.
/ T293 4WD? #3
Hi,
Thanks,
Mark Sorrells
Make sure all of the 4WD lever linkage joints are well lubed, and other than that try to shift it in when the tractor is just moving slightly.
/ T293 4WD? #4
yes, I had the exact same problem with my 293. It started as being a little difficult to shift, progressing to impossible. I could easily engage the 4wd from below, bypassing the linkage and moving the part attached to the trans axle. My dealer said it was in the hydraulic unit and decribed how I could remove the linkage and sand paper it smooth to aid in shifting. About that time I broke a hydraulic hose and lost all of the fluid, so I trailered it to the dealer and he fixed everything.
/ T293 4WD?
In April I applied WD40 to all of the linkages associated with the 4WD lever. Now it works better and easier that any other of the shifters!!
2017 Land Rover Discovery Sport AWD SUV (A64557)
2017 Land Rover...
SHOPBUILT MESH BOTTOM TRAILER (A64278)
SHOPBUILT MESH...
2012 FREIGHTLINER M2 6X4 T/A DAY CAB TRUCK (A66091)
2012 FREIGHTLINER...
2016 JOHN DEERE 7210R TRACTOR (A65054)
2016 JOHN DEERE...
INTERNATIONAL 5300 END WHEEL GRAIN DRILL (A64278)
INTERNATIONAL 5300...
2018 Kenworth T800 T/A Sleeper Cab Truck Tractor (A64194)
2018 Kenworth T800...
