Loader T234 loader slop
/ T234 loader slop
If is like the t273 I owned and the frame is not broken it soon will be. I repaired my two times before I made sub frame for it.
Any pics of your sub frame?
/ T234 loader slop
The only thing holding the 2 sides together on mine is 1 round hollow tube. The twist can happen at the quick connects/bucket or both loadermounts. Because I'm preventing it at the mounts with the washers...im hoping to prevent it from breaking.
/ T234 loader slop
/ T234 loader slop #16
The frame usually breaks where the bolts go through. Yes the hood pops open and also wires will rub the frame under the dash and cause a short. It will blow a inline fuse(40A) on the main wiring harness. If you can make a subframe or have someone do it it will solve the twisting problem.
/ T234 loader slop
Been contemplating a factory backhoe. That sub frame would work, right?
/ T234 loader slop #18
It should. The factory should have tied the front to back axle like the bigger tractors. I didn't know they made a backhoe for the small tym's?
/ T234 loader slop
It's a by200. It includes a subframe. $7000
/ T234 loader slop #20
Guess having a belly mower and its subframe helps my cabelas clone. Hadn't thought about it, but it would keep things straighter
(INOP) 2019 KUBOTA SVL 95-2S SKID STEER (A52707)
(INOP) 2019 KUBOTA...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
12' CONTAINER (A52706)
2011 DOOSAN G40 GENERATOR (A60736)
2011 DOOSAN G40...
2014 Ford Edge SUV (A56859)
2014 Ford Edge SUV...
36"x12' Stacks of Sheet Metal (A60463)
36"x12' Stacks of...
