T20 starting problem
/ T20 starting problem #1
haselhorst
Fergeson T20
I believe to start the T20 you have to push the shifter up to the right? I have not been able to start it this way and I have to short the solenoid. Is there an adjustment or ? Thanks
/ T20 starting problem #2
:welcome:
Is this a Ferguson TO-20?
Yes, when I bought it it was in a corral with horses and I had to repair most of the wiring. I can start it by using a screwdriver across the bolts on the relay but I can't start it using the shifter, I guess? I looked at youtube and it looks like they use the shifter some how.
/ T20 starting problem #4
You could add your own starter - push-button on the dash to close a solonoid to close the hot to the starter.
Or you could dig into the tranny and fix the mechanical switch (as I remember it anyway).
Do you have the I&T shop manual for the TO's ?
/ T20 starting problem #5
G'day from memory lift the stick up and all the way over to the right and forward to start if this does not work the switch just unscrews from the trans to replace it but if i remember right they are not cheap and have replaced a few as stated with a push button switch
Jon
New/Unused AGROTK YC-26G Horizontal Band Sawmill (A65583)
New/Unused AGROTK...
Danuser 3 Point Post Auger (A65640)
Danuser 3 Point...
2020 Bobcat S450 Compact Wheel Loader Skid Steer (A64553)
2020 Bobcat S450...
2015 INTERNATIONAL 4300 4X2 26FT NON CDL BOX TRUCK (A67147)
2015 INTERNATIONAL...
QUICK HITCH (A64277)
Kinze KM3000 Monitor (A65640)
Kinze KM3000...
