System Flush Required?
/ System Flush Required? #1
Beltzington
Platinum Member
Appling, Georgia
JD 3720
Rebuilding an 25-year old Morbark Wood Chipper, engine needed replacement so I have never seen it run. Seller said he used it once in the last 10-years before the engine blew.
Do I need to drain and flush the system before putting power to it? Simple system, reservoir is about a 15-gal vertical tank, pump is driven by 80HP Diesel off the disk shaft and this drives the two large feed rollers, start and stop valve and 8-hoses.
Although caps were in place, my guess is there is moisture in the system as it sat outside for years. So what would you do? Change the filter and see if it works? Full fluid and filter replacement? Full system flush using what procedures?
Appreciate your comments.
/ System Flush Required? #2
I would find out if it has water in the bottom of the tank and drain it out. Then change the filter and if the oil looks good I would try it out. I would change the oil after I knew the chipper worked well enough to invest more money in it.
The world is full of gear tractors with 25 year old hydraulic oil that still perform okay. What is more important is whether the fluid is clean, water, dirt and metal filings are detrimental to the systems. On tractors I like to make sure the fluid is correct, clean with no moisture since these systems have wet disc brakes that can break down with the use of improper spec fluids. On a simple system such as you have for the chipper the risk is much lower and I would wait to change the oil if it did not have water in it,
/ System Flush Required? #3
I would drain a little fluid and see if it looks new.
Check all filters
If the fluid was good when stored, it should be good.
If it was stored and the fluid was good and water did get in the hyd tank, it would go to the bottom and you could drain the water,
If you run the hyd system with water in the fluid, the water and fluid will emulsify and make some bad stuff and that needs changing right away, including a good flush.
Once you get the fluids right, and the engine running, check the hyd pressure to see how the pump and hyd system is performing.
Landhonor BH-12-72D Backhoe Skid Steer Mount (A62679)
Landhonor...
Towable Dual-Line Pipe Road Crossing Trailer (A63689)
Towable Dual-Line...
2025 Auger Bits Skid Steer Attachment (A61567)
2025 Auger Bits...
FORD F750 BUCKET TRUCK (A65054)
FORD F750 BUCKET...
2019 HINO 268 26FT 4X2 S/A NON CDL BOX TRUCK (A59914)
2019 HINO 268 26FT...
2007 International 4300 Bucket Truck 55' (A62613)
2007 International...
