Synthetic Hydraulic Fluid & FEL performance
   / Synthetic Hydraulic Fluid & FEL performance #1
buzst
south NH
Kubota B2150HSD
Last fall I changed out the UDT in my B2150 for Super UDT to help with cold weather performance. I did get better cold weather performance but also experienced about a 20% reduction in loader lift capacity. Kubota tech suggested that this is because the better flow of super UDT permits easier bypass of worn components thus reducing lift cap. I am about to change fluids again and would like to use a pure synthetic to eliminate hydo whine, but I'm concerened that loader performance may suffer even more (my understanding is that Super UDT is a blend) Any thoughts? Is there a Synthetic fluid that is "heavier" than others that may perform better?
   / Synthetic Hydraulic Fluid & FEL performance #2
The whine will be there no matter what oil you use. I do believe unless you have put a lot of hours on your tractor that the rep gave you a lame excuse. I would wonder how you knew that you had a 20% reduction in load capacity? You may have had a relief valve get a little weaker but that can be adjusted.
Thanks Art I figure 20% because the rated lift is 840lbs and last fall I moved a rock (picture in one of my old posts) that I could not lift again after changing fluids. This summer I did a patio project using 50lb concrete blocks and the loader could only lift 12 of them at a time.
Is the relief valve something I can adjust myself?
   / Synthetic Hydraulic Fluid & FEL performance #4
you mentioned hydraulic whine... I would do a pressure test and see if the pump is doing as it should. The whine might indicate a unhealthy pump, but maybe not, I have seen pumps that whined bad and worked fine for many years. Just a thought....
slowrev, the whine I was refering to I think is the "normal" noise produced by hydro tranny. I though I had read here in other postings that Syn fluid would help reduce this noise?
   / Synthetic Hydraulic Fluid & FEL performance #6
No problem if normal whine, but I have heard the whine keep getting louder as a pump breakdown approached. Hope yours is the normal level /forums/images/graemlins/smile.gif
   / Synthetic Hydraulic Fluid & FEL performance #7
<font color="blue"> I though I had read here in other postings that Syn fluid would help reduce this noise? </font>
I am going from memory, so please bear with me. /forums/images/graemlins/tongue.gif
There is a specific 'problem' that affects Class II NH Boomers when the hydraulic fluid is cold. There's a louder than normal whine when using the FEL until the fluid warms up. It doesn't hurt anything, it's just annoying. The 'real' fix from NH is to replace some steel lines with rubber. In some (all?) cases switching to a synthetic hydraulic oil, which flows better when cold, has also resolved the problem.
   / Synthetic Hydraulic Fluid & FEL performance #8
New Holland also suggests the use of F200 Hydro Fluid in place of NH134D in colder climates. They say it can be used year round! To my knowledge, it is NOT synthetic, but rather multi viscosity. My 7308 Loader screams when the temp. drops below 10 deg. I plan to switch to F200 at the 300 hour fluid change. I understand also, that the "float" position of the bucket will not engage while this "whine" condition is present. If you use your loader for snow removal, you shoul consider this also!
   / Synthetic Hydraulic Fluid & FEL performance #9
<font color="blue"> My 7308 Loader screams when the temp. drops below 10 deg. I plan to switch to F200 at the 300 hour fluid change. </font>
In preparation for this winter, this is why I switched to Amsoil synthetic hydraulic fluid.
   / Synthetic Hydraulic Fluid & FEL performance #10
Mike: How or why is Amsoil Synthetic better than NH F200? Is it suitable for year roud use?
   / Synthetic Hydraulic Fluid & FEL performance #11
<font color="blue"> How or why is Amsoil Synthetic better than NH F200?</font>
It's not just a thinner oil, as previous posts about F200 indicate. It's a full synthetic that flows at -40F.
<font color="blue">Is it suitable for year roud use? </font>
Yep.
   / Synthetic Hydraulic Fluid & FEL performance #12
Check out Chevron All-Weather THF. Its a full synthetic rated for your machine. And like the Amsoil it does not improve cold flow by lowering the viscosity of the fluid. Just a fluid with a great natural viscosity index.
   / Synthetic Hydraulic Fluid & FEL performance #13
<font color="blue"> Check out Chevron All-Weather THF.</font>
I've already switched to Amsoil. /forums/images/graemlins/smile.gif
<font color="blue">And like the Amsoil it does not improve cold flow by lowering the viscosity of the fluid. </font>
Did you mean 'And like the Amsoil it does improve cold flow...'
   / Synthetic Hydraulic Fluid & FEL performance #15
Mike: Which Amsoil product did you use? I went to their website and found several versions. Is one more correct than the others?
   / Synthetic Hydraulic Fluid & FEL performance #16
<font color="blue"> Which Amsoil product did you use? </font>
Synthetic Tractor Hydraulic/Transmission Fluid, C-3, C-4.
There are 5 different ways to order this, from 1 quart bottles to a 55 gallon drum, but it's the only Amsoil hydraulic fluid I am aware of.
<font color="blue"> I went to their website and found several versions. </font>
What other products did you see?
   / Synthetic Hydraulic Fluid & FEL performance #17
Hydraulic oils available from Amsoil:
Synthetic Tractor Hydraulic/Transmission Fluid (ISO46, SAE30) ATH Available in qts, pails, drums
Synthetic Hydraulic Oil (ISO15) AWF Available in pails and drums
Synthetic Hydraulic Oil (ISO22) AWG Available in pails and drums
Synthetic Hydraulic Oil (ISO32) AWH Available in pails and drums
Synthetic Hydraulic Oil (ISO46) AWI Available in pails and drums
Synthetic Hydraulic Oil (ISO68) AWJ Available in pails and drums
Synthetic Hydraulic Oil (ISO100) AWK Available in pails and drums
Contact me and I can give you more info: dave@ultimateoiltechnology.com
Dave
   / Synthetic Hydraulic Fluid & FEL performance #18
<font color="blue"> Hydraulic oils available from Amsoil: </font>
The context of this discussion is tractor hydraulics therefore the only Amsoil product that applies is ATH-Synthetic Tractor Hydraulic/Transmission Fluid, ISO 46, SAE 30
None of the other ones you mentioned apply.
<font color="blue"> Contact me and I can give you more info: dave@ultimateoiltechnology.com </font>
TBN offers very reasonable advertising rates for your oil business. /forums/images/graemlins/smirk.gif
   / Synthetic Hydraulic Fluid & FEL performance #19
<font color="blue">
</font> The question was whether there was one Amsoil hydraulic oil or several. There are several, but you are correct, only one applies.
<font color="blue">
TBN offers very reasonable advertising rates for your oil business. /forums/images/graemlins/smirk.gif </font>
These forums are a great source for ideas and information. Thanks for the info /forums/images/graemlins/smirk.gif
Mini John Deere Truck (A55853)
Mini John Deere...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
iDrive TDS-2010H...
2014 Nissan Murano SUV (A59231)
2014 Nissan Murano...
2009 Landoll 435A 50ft. 43 Ton T/A Tilt Deck Equipment Trailer (A60460)
2009 Landoll 435A...
