Switches
/ Switches #1
turbotime
Hey guys, this is a bit off topic. Just wondering if anyone knows where I can get some lit switches, like the ones Deere has in-cab for the beacon. (on a 3520, green light)
I'd like to possibly be able to order them already customized and labeled with either description for application or the symbol. And possibly different colors.
Thanks in advance!
/ Switches #2
I don't know about the labeling, but you can order the JD switches from any JD dealer. You just need to find the part number for the one you like. That you can do on JDParts.com.
/ Switches
Thanks for your help! However, upon checking prices they all hover around the 50$ mark:eek:
Ah yes, I forgot, they're the gold plated series!
/ Switches #5
Yo can also find the Carling Contura series of sealed rocker switches at Waytek ( Welcome to Waytek Wire )
I installed 4 illuminated Contura switches on my 2520 open station. Great switch that tolerates the winter weather quite well.
/ Switches #6
/ Switches #8
I bought a Deere SPST switch from the dealer for $17.00. I used it for rear facing lights on my 3320. I put it in just left of the steering wheel. I am at work or I would give the part #.
Dan
/ Switches #9
I will second burtco99's recomendation about Waytek. I have been dealing with them for years for most of my low voltage electrical supplies. Great company, good pricing and very fast delivery.
/ Switches #12
I've gotten some of the switches from Wes-Garde components....great place to deal with...BUT has minimum orders....so I have a small "Overstock" in the basement of DPDT's...
Yes in theory you can get them custom printed with a HUGE list of standard symbols, problem is the minimum order number.
I think if something were a "must have" and alot of people wanted to jump on it we could probably arrange a group buy and get it done, but I doubt the TBN crowd would do it in the numbers required...
/ Switches
Wow, thanks for all the suggestions guys! Was not sure if I'd get much of a response. While looking I did find Carling's V-Series switches. They look real clean and somewhat comparable to the rocker's in our Deeres.
I am in contact with my Allied Electronics' local manager to discuss a possible order.
Problem with my order is that I want everything custom labeled! Hopefully it won't be too much of a wallet burner. I'm hoping to order around 9 switches along with proper mounting plates/panels.
These are actually going into my truck.
Thanks again all.
/ Switches
Would you mind posting pictures? I'm interested in seeing your set up:)
/ Switches #15
I have one of Sputland Daves switches and it is an exact match tot he switches in the tractor from the factory. I set it up to run the worklights on my cab independantly so i can plow without the glare. I need to take a few pics of it. I will post it here...
/ Switches #16
You can also go to your local Napa autoparts store, I have had to replace a switch on mine you can get industrial waterproof switches in almost any color of led light for ususally $10 bucks or less depending on how many terminals it has
/ Switches #17
If you get somewhere with that, PLEASE let me know...I'd like a few custom labeled versions as well...
/ Switches
Still no response from the guy...he said he was getting me a quote. I'll see if he gets back to me this week. You should see the order form for the custom labels and all those shenanigans!:eek: lol
/ Switches #19
I just installed the beacon light on my 3720 cab it was a easy 15 min install.The rocker switch was iluminated which was nice and i was wondering if deere has any other switches(windshield wiper rear worklight etc.)that are iluminated as well.I tried looking in the jd parts section but had no luck. Love to find some with the lableing and lighted it would be nice when working at night.
/ Switches #20
I'm not familiar with the exact switch because my tractor is orange but here is a good source for waterproof switches. Cheap like 5 dollars. SPST Waterproof Miniature Rocker Switch (On-Off) 16A Green 12V - VETCO.NET
They are made by NTE electronics NTE-Electronic Components Supplier-Catalog-Cross Reference-NTE Electronics 54-203w their website has a list of distributors
FUEL TANK (A68842)
FUEL TANK (A68842)
2021 WEILER K560 KNUCKLEBOOM LOADER (A65057)
2021 WEILER K560...
2019 Peterbilt 520 T/A EZ-Pack 40Yd Front Loader Garbage Truck (A66736)
2019 Peterbilt 520...
Giyi GY-CW59 QA  70" Padfoot Compactor (A64912)
Giyi GY-CW59 QA...
STIHL FS80R POLE SAW (A64276)
STIHL FS80R POLE...
500 BBL FRAC TANK (A67714)
500 BBL FRAC TANK...
