Loaderman22
- Joined
- Jan 11, 2017
- Messages
- 1,114
- Location
- Hudson Valley, NY
- Tractor
- 1947 Ford 2N, 75 MF 30B, 75 Swinger Loader, 1979 Cat D3
Hello everyone,
I'm not sure where exactly to file this question. I have a Swinger articulating loader, with a Ford 172G 4 cyl. gas rear engine, Marvel updraft carb. & a hydrostatic trans with driveshafts to what I believe are GM (maybe Dana 70's) axles. This thing is super handy & maneuverable, decent power, 4wd and kinda fun to drive. I have done a fair amount of work to it, new starter, alternator, cables, but has had a few fuel issues. After using it one day, I noticed the carb started leaking gas. I shut off fuel & figured the float was stuck down. I pulled carb & hanged float needle & seat with new. The old looked perfect, but did it anyway. Set float to 1/4" off top half of carb, & left all other adjustments alone. Shook carb & could hear float moving up & down. Reinstall carb & it leaks. Remove & test float, floats in cold water, & no bubbles or hissing in hot water, no dents, & no signs of cracks. Rei stall & now it's picky, leaks sometimes, mostly out of air intake tube where it meets carb. But other times it doesn't leak at all. But it would typically run fine, just leak if gas isnt shut off when done. However the last few months its been running very weird, during the NY blizzard a couple months ago it ran perfect, other than that it starts fine & runs good for only a minute, after that it spits & sputters unless I pull out & hold choke almost all the way, then it runs as it should. I haven't touched a thing in the carb, but suddenly this weird bogging with choke open issue. If I hold choke out, runs great but I'm lost as to why. Do I need to clean carb? Maybe some dirt got in there?. Any thoughts? I thought maybe the gas leaking issue was a symptom or related.
