Swapping Robin out with Kohler today
   / Swapping Robin out with Kohler today
Terry has been great. I ordered the engine stand for the Kohler today from PT along with a new wire harness, couplers, hour meter and ignition switch.
I was thinking about draining the hydraulic tank, and possibly using synthetic. Any thoughts on this?
   / Swapping Robin out with Kohler today #13
I did that. I can't say that I noticed any difference. I was glad to see how clean the tank was at the very bottom.
I put in Mobil synthetic 15W50, but there is no appreciable difference when hot, so I would stick with 15W40.
YMMV.
All the best,
Peter
   / Swapping Robin out with Kohler today #14
I've been adding Mobil1 to the hydraulic tank each time I do my 50 hour filter change since 2001. So, I have about 10-12 quarts diluting the original factory oil. Can't say I notice any difference because it's been such a gradual dilution. But then again, I can't say I'm disappointed with the way the thing works, either. I'd be curious to look in the bottom of my tank. Maybe I'll dissect a filter this time after I change it.
   / Swapping Robin out with Kohler today #15
I think the only real note MIGHT be the oil running cooler. Seems to be a theory for whatever reason going around that Synthetic keep a device a bit cooler.
I put in the cheapest 10/40 I can find, primarily because my tractor tends to use more oil than Diesel.
   / Swapping Robin out with Kohler today #16
If your thermostat is functioning, how can the oil run cooler?
Confused,
Peter
I believe this is a solenoid. It has a red wire that goes to the starter. Was wondering where I can find a replacement. It is attached to the inside of the of the tub by the starter. Image.jpgImage 1.jpg
Thanks
Frank
The one hose coming off the oil cooler is a piece of cake to swap out, however the second looks like it is going to be a real headache. In the front lower left hand corner of the tub there is a manifold of hoses that tie into the reservoir. This hose appears to be on the bottom row under these here in the picture. I am guessing I will have to take all these hoses off to get to the one I need to take off.Image 2.jpg
   / Swapping Robin out with Kohler today #19
It would have been nice if PT had hard-piped most of the hydraulics in the engine compartment (except for the point of connections to the pumps and going through the tunnel). Would have save a bunch of room and made the beast easier to maintain.
At a sticking point with one of the cooler hydraulic hoses. It is in the lower left corner of the tub at the reservoir. There are five other hoses. I removed the hose over top of it and one to the side, however I still cannot get a wrench on the fitting. The male fitting of the hose I removed is in the way. Are there special wrenches for this? Real tight spot and afraid if the I were to get a wrench on it, if it slips I will mess up the threads on male fitting directly above. I agree 1000% with you Tim, hard piping definitely would have been better in the tub.
Unused 2025 CFG Industrial QH12R Mini Excavator (A59228)
Unused 2025 CFG...
Unused 2025 CFG Industrial MX12RX Mini Excavator (A59228)
Unused 2025 CFG...
2015 New Holland T4.95 MFWD Cab Tractor (A55314)
2015 New Holland...
iDrive TDS-2010H...
iDrive TDS-2010H...
2012 JACK COUNTY 130 BBL STEEL (A58214)
2012 JACK COUNTY...
