Surface prep... sandblast vs. grind?
/ Surface prep... sandblast vs. grind?
Back here
http://www.tractorbynet.com/forums/build-yourself/376766-cutting-down-back-blade-good-4.html
texasranger556 suggested using one of the HF magnetic tool holders as a guide - at the time I thought "he didn't read the part about the CURVED surface - but I "filed it away for later" - today I was making a 2.5x as thick "deck skirt" for my Cub RZT 50 (thread likely in next few days) so I thought I'd try his idea (he also has a PM45) - for straight cuts on FLAT material (up to about 14" per tool holder) I was AMAZED -
Those SPECIFIC ones have a curved channel with magnets glued inside, and they're enameled - as it works out, if you hold the nozzle of the PM45 torch up against that curve, it puts the tip less than 1/16" off the surface AND gives you that smooth enameled surface to drag on. Smoothest NON-wheelie cuts I've made in a LONG time...
When I post my deck repair thread it'll be clearer what I meant by "non-wheelie"... Steve
Steve, texasranger, I am still not understanding how this works for a curved surface? Is the HF magnet flat and flexible? :confused3:
/ Surface prep... sandblast vs. grind? #42
Sorry, didn't explain that very well - the magnet is NOT flexible (but you have a 20 ton press, soooo...
Seriously tho - I meant that the CHANNEL the magnets are glued into has RADIUSED edges (like if you rounded off the outer corners of a piece of small C channel - it will NOT work on a curved surface like a grader blade. Straight line cuts on FLAT material ONLY.
The Radiused edges are on the side that does NOT stick to the metal, and they are shaped almost EXACTLY the same as the PROFILE of the PM45 torch, so if you hold the torch fairly firmly against the side of the strip the torch will ride up just enough to leave a small gap between the torch tip and the metal - just enough to get away from the extra coefficient of friction between torch tip and metal.
Only way I know to cut curved metal is to use something that's flexible enough to conform to the curve, usually the convex side - cutting a large cylinder SQUARE is easiest, just make your "flexi-strip" straight on one side, then wrap it all the way around the pipe, overlap ends so they're flush on the cut side, and unless you pulled the strip so hard you deformed it, the result should be @ 90* to the length of the pipe.
Sorry for the confusion - if your "blade boo-boo" eats at you TOO much (and I've BEEN there :confused:) you could always stand your blade on end over a piece of flat bar, tack that in place, WELD it in place, then hold your plaz against the blade surface itself and "trim" the excess flat bar away - that'd give you more plaz practice, more welding practice, more practice being VERY patient, and MAYBE even a nice straight edge on the end of your blade ... :D ...Steve
2007 DRAGON 130BBL VAC TRAILER (A63569)
2007 DRAGON 130BBL...
ROADTEC RX700 MILLING MACHINE (A62129)
ROADTEC RX700...
2009 CPS Manac SGH36 Hopper Bottom (A64047)
2009 CPS Manac...
NO ADDITIONAL ONLINE BUYERS PREMIUM ON BID.FIVESTARAUCTION.COM (A64047)
NO ADDITIONAL...
2022 EZ-GO ELITE...
Finn KR8P Straw Chopper/Crimper (A64047)
Finn KR8P Straw...
