Surefire flashlights
   / Surefire flashlights #11
JB4310 said:
I was just at Lowes today and was surprised to see they now have Surefire lights, one was priced at $60.00 for 80 lumen's, another tag said $80.00 but they were out of that one. Didn't see if they took the special batteries or not.
Coast is a company that makes decent quality lights for a moderate price
. Tactical Use Lights :: Coast LED Lenser Lights :: Discount LED Lights & Knives
I saw them at Lowe's as well. I believe most of them use the CR123 battery at about $5.00 each. I have one. I use it sparingly. Pelican also most some similar to the Surefire M6.
   / Surefire flashlights #12
All off Surefires lights use CR123 lithium batteries except for a handfull of lights that are rechargable. You can purchase the Surefire battery's directly off their website for about $1.75 plus shipping.
Ken - the $499 Titan light you were looking at was a limited edition light that was made out of titanium. An aluminum version will be offered latter this year.
Althought $499 is more then a little spendy for a flashlight keep in mind that with Surefire you are getting what you pay for and Surefire offers a lot of other more cost effective models. I'm a flashlight geek and used to be a First Responder. I've have had enought cheaper lights and some not so cheap lights fail when I needed them that I just stick with Surefire products. I currently have more then a dozen Surefire lights.
If you just looking for a flashlight to use around the garage just about any brands light will do. But if you need a light that will work in extremious, regardless of the temp or rain and need it must work every time, then Surefire is one of the few brands that you can bet your life on.
   / Surefire flashlights #13
You can get the CR125 batteries for under $2/each at a place that sells police supplies or directly from surefire for $1.75 (order of 12) .. DO NOT buy them at walmart or other retailers, you will pay too much..
Brian
   / Surefire flashlights #14
Surefire makes the best lights hands down, they are the leader.:D
When your life is on the line you want the BEST, I bought mine on ebay for 1/2 the price of the local cop shop. $50.00
When things go bump in the dark, you want to make sure of your target or path ahead.
If you want a light just to see in the dark the leds are the way to go.
   / Surefire flashlights #15
Ah, flashlights. I have about 20 in my small collection. I am a long standing member of Candle Power Forums. Five of my lights are Surefire. I find a Streamlight Apex headlanp works great when you need both hand free. It has a 3W LED and 4 small LED's that can be run on high or low power. I run it with the new Sanyo Eneelop batteries. They are a new technology low self discharge rechargeable battery.
I'm big on high power LED flashlight.
GaryM.
You are right about Fenix. It's a good quality light that comes in many configuration. Some have the latest Cree Q5 leds. Up to 240 lumans on the new Cree's.
CR123 can be had for $1.00-1.25 if you know good internet sites and there are rechargeable versions now.
I have a 3D Mag that I modded to 800 lumens out the front. Some of my friends have made flashlights that can set paper on fire.
My EDC (Every day carry) flashlight has been, for the last 6 years, an Arc AAA powered light. 9 lumens output, military grade hard anodizing (HA III), waterproof to 100 and a no questions asked lifetime warrenty.
   / Surefire flashlights #16
Dana,
Sounds like your kinda a flashlight guru,
Whats the true measure of a lights brightness/output is it the lumens or the watts or a combination of the 2, I just picked up an led lenser from coast it says 3.44 watts and 60 lumens, 3 AAA's, cost around 30 bucks. How do those specs rate in the flashlight realm.
We use the streamlight headlights with the 1, 3, or 10 led position switch, they work well for our work in basements, I just picked up another SL HL with 3 leds and 1 reg bulb have not tried it yet.
Thanks, JB.
   / Surefire flashlights #17
Geez, that's a tough one. In general, lumens are the best measure. Candlepower is measured in a globular pattern whereas lumens are measured at a target 1 from the source.
Watts aren't too bad to use as a general measure but not nearly as good as lumens. I could have an older 3 watt LED that puts out 50-60 lumens and put that up against a new Cree XR-E Q5 LED that can put out 240 lumens at the source.
That's because the technology of LED's is improving at a fast rate. LED efficiency measured in Lumenius(sp?) Flux. Three watts of power is now brighter in the latest LED's compared to the older ones at the same power draw.
Compare it to vacuum cleaners. "My vacuum has an 11 amp motor" Mine has a 12 amp motor? The one with an 11 amps may be the better one due to the efficiency of the motor. Clear as a bell, huh?
Even the little 5mm LED'S have improved. The latest ones are 40% brighter at the same current. I have a flashlight in my pocket that uses the new Nichia DS and now the GS is out that's 10% brighter than the DS.
Link to Arc Flashlights
When you get into incandesint lights, watts are a little better to compare with but not always. I have a Streamlight Ultra-Stinger that is 10W and a Pelican Surge that is 7.5W. The stinger is brighter at the source. If the Pelican had a tighter focus, it would seem brighter to the eye.
My 3D Mag has a 20W bulb and a tight focus. It's what I call a barn burner.
As for headlamps, I will only use LED's. Way brighter, less heat and a longer battery life. A great headlamp is the Princeton Tec EOS. A 3 watter with 3 levels of brightness, 3AAA batteries on the front.
A rear battery, 4AA, is the Princeton Tec Apex. And it can be modded to twice as bright for $14. See this thread Princeton Tech Apex Mod - Step by Step - CandlePowerForums
I really like my flashlight hobby.
   / Surefire flashlights #18
Thanks, I checked out the links, didn't realize there were flashlight freaks like that, very interesting.
What would your choice be for an all around best light, If you could only have 1 light.
   / Surefire flashlights #19
Wow, thanks for the info on batteries. My son gave me a surefire but I don't use it because of the 6.00 battery. If I can find em for 2 I would use it more.
   / Surefire flashlights #20
I've been a member there too for a while. I don't post much, but lots of information to be gained by reading the posts. Just like here!
UNUSED WOLVERINE GB-11-72W 72" HYD GRAPPLE BUCKET (A54757)
UNUSED WOLVERINE...
2025 78in Rock Bucket Skid Steer Attachment (A55787)
2025 78in Rock...
Toro Cart Run and Drive (A50324)
Toro Cart Run and...
2013 East Manufacturing 45ft T/A Walking Floor Trailer (A55788)
2013 East...
2019 Caterpillar DP35N 7,000lb Diesel Forklift (A51691)
2019 Caterpillar...
(10) 2" X 5" & 4" X 10' CHANNEL IRON (A54756)
(10) 2" X 5" & 4"...
