Summit Monoblock Directional Control Valve
/ Summit Monoblock Directional Control Valve #1
mechtheist
Canyon Lake
Branson 3520H
I want to add an hydraulic top link to my 3520 and I'm thinking I can use the backhoe hydraulics lines. I've seen a lot of diverter valve/multiplier options but this thing looks like it would do just fine and it's only $109. I've tried searching and don't see it mentioned so am I missing something? The info:
Monoblock Hydraulic Directional Control Valve, 2 Spool, 11 GPM
SKU: P402-2A1
This manual monoblock valve is a hydraulic directional control valve. These valves are used to start and stop fluid flow into hydraulic cylinders or hydraulic motors.
Common Uses:
  • Operate hydraulic cylinders (Double-Acting or Single-Acting)
  • Operate hydraulic motors (“D” Spool Required)
  • Install rear remotes on a tractor
Benefits:​
  • 2 Spool valve with compact design allows for installations in tight areas
  • All spools are standard double acting with spring return to neutral position which are ideal for double acting cylinders
  • Used for open center systems (Pump to Tank Flow) – closed center option available
  • Anti-drop load checks on each spool
  • Precision ground and hard chrome-plated spools assure a long life
  • High-tensile strength cast iron monoblock construction
  • SAE O-Ring ports ensure solid seal and prevent blockages
  • Capable of closed center or Power Beyond (conversion plug required)
  • Vertical or horizontal handle mount
  • Adjustable Relief Valve Range: 1500 to 3625 PSI
  • Preset Pressure Relief: 2610 PSI
  • Used as motor or single-acting spool possible (#8 SAE port plug required)
Features:​
  • Max Operating Pressure: P = 3625 PSI, T = 725 PSI, A & B = 4350 PSI
  • Flow Rating: 11 GPM (40 l/min)
  • A & B Work Ports: #8 SAE O-Ring (3/4”-16) Thread
  • Inlet Port: #10 SAE O-Ring (7/8”-14) Thread
  • Outlet Port: #10 SAE O-Ring (7/8”-14) Thread
  • 2 – 5/16” Mounting Holes
If I understand it, you could hook it up either with the backhoe lines permanently hooked up or with them temporarily connected depending on whether you use the power-beyond option. Is this viable? I realize there will be connector/adapter issues but that's solvable. If it's this easy, I wonder why it doesn't seem to be mentioned here, which is why I think I'm missing something. Thanks for any help.
/ Summit Monoblock Directional Control Valve #2
I am guessing that your backhoe is plumbed off of the loader valve power beyond. If that is the case, then I would simply put this valve after the loader valve and before the backhoe.
Get the power beyond conversion plug and use it to feed the backhoe.
/ Summit Monoblock Directional Control Valve #3
That valve will work just fine. May not be very ergonomic compared to the factory remote setup but that also depends how you're going to mount it.
For your application, might be worth to spend a couple more bucks and get one of the spools with detent. Then you can run the backhoe right of the valve and just use the detent to keep the lever engaged, instead of a bungee rope or something.
/ Summit Monoblock Directional Control Valve #4
A detent with pressure kick out will be problematic powering a backhoe. Every time a cylinder reaches the end of its stroke the detent will release. Non-cancelling detents are rare on open center valve and potentially hazardous to gear pumps. That's why bungees or a mechanical means to lock the spool are so often seen and used.
/ Summit Monoblock Directional Control Valve #5
Yes, I'm aware of that, however, the valve the OP showed, it's actually a Badestnost valve, just rebranded to something else and those are available all over the place on this side of the pond. Those valves have non-cancelling detents. A mechanical lock or a bungee cord can also be problematic if the OP doesn't take it off, just like the detent.
/ Summit Monoblock Directional Control Valve #6
Absolutely. My post was directed to the OP in an effort for him to understand a typical kick out detent wouldn't be a satisfactory choice to power a backhoe or anything with an additional valve.
Folks post here frequently complaining of poor results from that strategy.
Thanks for your replies. My thinking was to just use the backhoe feed and disconnect it and connect the backhoe if I'm using it. This is a diagram on Summit's site, I think it's more or less what y'all are talking about. Does it matter where the flow is coming from? I have virtually zero hydraulics knowhow. What's the difference between coming directly from the pump and going to the loader valve and from its power beyond port? My [ignorant] thinking here would be if you used the power beyond on this, it would be as if the two hoses together as you have to do when the backhoe is off. I don't understand the problem with the loader valves if that is where the backhoe line comes from.
/ Summit Monoblock Directional Control Valve #8
That will work exactly as shown so long as the Summit valve gpm rating is sufficient to carry 100% of your tractor's hydraulic flow for the loader circuit.
It's rated at 11gpm, the 3520 is 9.
/ Summit Monoblock Directional Control Valve #10
The tank port on this valve is rated for 725 psi. Your tractor goes to about 2500. If you plumb the tank port into the 3pt (which is what you'd do if you put it in the BH loop) you'll damage the valve the first time you pick up something heavy on the 3pt.
You need to get it with a PB port and run that to the 3pt and tee the tank into the tank line from the loader. I'll second @ptsg's suggestion to get a valve with a detent on one spool to run the BH off of. Then you can get rid of the BH loop sticking out the back. I'll also suggest that you get a valve with a spool that goes into float. It can be useful for some implements.
I have two factory valves and a dealer installed 3rd valve on the fender. I moved the lever to point forwards instead of up and it's very easy to use that way. This valve would let you do the same.
/ Summit Monoblock Directional Control Valve #11
Post #7 clearly shows the tank port of the newly added valve going directly to tank.
My plan is to hook the BH lines to the new valve, not bother with PB, if I need the BH, just switch the lines. I'm not sure I understand how the loader gets involved. Does the hydraulic fluid to the BH come off the loader?
/ Summit Monoblock Directional Control Valve #13
Typically pump flow goes to the loader valve first then on to remotes, pb for a backhoe (if so equipped) and finally to the 3 pt hitch valve.
/ Summit Monoblock Directional Control Valve #14
Yes the backhoe most likely gets its fluid from the loader valve through the power beyond port.
If you look at the diagram you posted in post 7 you can see how the flow works. If you ignore the new valve in the diagram and just draw a line from the loader valve PB to the Power in for the backhoe that is how it works.
Your Three point hitch valve gets its power through loader valve as well.
That's a Summit example but it looks like it is also how the 3520 is connected. Below is from the 3520 Service Manual. The red labels are added. Since I don't have rear remotes, that must be standard on the cabin model, I'm assuming the backhoe setup just uses the same lines and the way it looks on the tractor kinda resembles the schematic drawing '7'. If that's true, then it's pump to front valve to backhoe to rear-3pt.
I'm a lot more familiar with electric systems but I know they are highly analogous. To me, the lines that flow from the pump through the various valve inputs to their powerbeyonds is like the voltage rail for a power supply, they're 'shorts', so if you removed a valve and replaced it with a pipe or hose from inlet to powerbeyond outlet, nothing would change downstream [assuming no inputs to whatever the valve was controlling to muck up the analogy].
If that's the case, then when the backhoe is attached, the 3pt. hydraulics are getting 'used' hydraulic flow but that's fine since the 3pt bits are all disassembled when the backhoe is there so you won't be using the lift arms. [But then, how does that flow get to the tank? See below]
So that brings me back to the question of what is the issue with the loader valve wrt the backhoe hydraulic lines and the tank port ratings etc? The tank port only gets flow from the fluid used on the front loader and it's really really unlikely they'd ever both be getting used at the same time. It seems like installing this valve controller would essentially be adding the rear remotes that come with the cabin model.
The electrical analogy only goes so far, power supplies don't mind at all if they're facing an open circuit but hydraulic pumps have to flow if I understand it correctly else they'll burn out. So if you only go to one valve, if it's not in use, the high pressure flow has to go somewhere and I assume from prior posts above it can't just be shunted directly to the tank so how is that handled? Also, why can't you just 't' off for any valves needed like you could in an electrical circuit and do away with powerbeyond? I appreciate the patience shown here, I'm trying to get a handle on these things and it takes a while to sink in my ignorant decrepit head.
trx-cap --  - 12_10_2021 , 09_32_06 - Branson 20 series service manual_ - PDF-XChange Editor.png
/ Summit Monoblock Directional Control Valve #16
Okay, forget about electric systems or hydraulic systems for a moment.
Lets say you have one outside water faucet with a splitter. Then you have two garden hose hooked to that splitter. At the end of each hose is a sprinkler. When you open the valve both sprinklers will work.
Now turn off the water and remove one sprinkler and leave that hose open. What happens to the other sprinkler when you turn the water back on? It will not work because all your water is taking the path of least resistance out the hose that is open.
Same thing with splitting a supply line on a open center hydraulic system. You will not be opening both control valves at the same time so the fluid will take the path of least resistance which is thru the valve not used and back to tank. You will not have any power to move a cylinder.
Now think of that water hose again. If you have only one hose and crimp off the flow, what happens to the pressure? It climbs till it reaches equal pressure that is in your water system.
When you use the tank port of a hydraulic valve to feed another valve and you use the new valve the line pressure builds to equal pressure of the system. This back pressure on the tank port will fracture the valve because it is designed to be open with only flow pressure. When you use the power beyond sleeve that port now can handle the system pressure.
Does that make sense now?
/ Summit Monoblock Directional Control Valve #17
I have a backhoe for my 4820R. With the backhoe package, additional hydraulic lines are added, larger than the rear remotes which I have. When the backhoe is off the tractor, the backhoe hydraulic lines are connected together and fluid flows through unless hydraulic fluid is used somewhere upstream. The factory rear remotes on my tractor are 1 spring and 1 detent. I plan to get a hydraulic top link soon. In the future, I want to add a hydraulic thumb on the backhoe connected to the detent rear valve. I'll add another valve by the backhoe controls to operate the thumb.
/ Summit Monoblock Directional Control Valve #18
The flow goes through all the valves in series. Pump -> loader -> 3pt. On each valve the flow goes out the tank port or PB port if the valve has PB, and on to the next valve. Unless the valve is actuated, then flow goes out the work ports. When you operate the 3pt, the pressure to run that comes from the pump, through the loader valve.
Now add an additional valve: Pump -> loader -> new valve -> 3pt. The pressure to lift the 3pt goes through the new valve. If you plumb it without using PB the tank port will see that pressure, which maxes out at about 2500 psi.
There are valves with tank ports that can handle full pressure. The dealer installed additional remote on my 3725 is one. But they are not that common.
BTW the last time I heard the factory remote kit was a lot less than other manufacturer's remote kits. With all the stuff you'll need to buy to DIY, easily another $150, plus fabbing brackets, it might make sense to price the factory kit. It does integrate nicely in the cabin.
It makes sense but it doesn't answer the main thing I don't understand. [Plus, if I forget about hydraulic systems, how am I then to think about water in a hose?] From what you're saying, it must be the case that the hydraulic system can have the fluid flow blocked most of the time, it's the only way for pressure to build up, so my stated assumption was completely wrong. If using the powerbeyond in a valve, then the downstream valve would have to NOT use its PB or, basically, the last valve would have to NOT have its PB connected to anything [which is kinda true by definition].
I haven't suggested using the tank outlet anywhere or if I did, it wasn't intentional.
In my 3520, what I guess is going on is the backhoe hoses are downstream of the PB on the loader valve which then goes to the 3pt lift valve which is where the end of the line is that allows the pressure to build. I hope I have got it right now?
/ Summit Monoblock Directional Control Valve #20
Fluid flow is not blocked most of the time. It is redirected to perform some type of work. This is why they call the valve a directional control valve. Fluid is always flowing somewhere as long as the pump is pumping.
I guess I do not understand what your main thing you don't understand is.
