suitcase weights
/ suitcase weights #1
candyman
oh
Kubota 2011 MX5100 W/la844 loader, ag/ tires loaded, Massey Ferguson 2010 GC2610 TLB w/ r4 tires, loaded, 60" Belly Mower
we have a gc2610 tlb are there weights for the front end. could not find any info. { searched } & of course the dealer is of no help.
when the bucket is empty the front end is just to light. have a grill guard on it & looks like there is a place to hang weights.
any help is greatly appreciated.
thanks
/ suitcase weights #3
If you are looking to add weight to the front end while keeping the FEL installed, your options are going to be limited. There is not a lot of clearance between the grill guard and the cross member on the FEL.
I also wanted to add some weight to the front. The only thing I came up with that I was willing to do was add Rimguard to the front tires. The tires are small any only hold a few gallons, but the extra 30-40 lbs does help a little bit.
Wheel weights may also be available, but I have not looked to see it small enough ones are made.
/ suitcase weights
i checked on the company in texas, did not see anything for my tractor.
fel is always on but the front end is to light, with what you said about loaded tires & wheel wghts. surely someone has come up with an idea on how to add front suitcase weights.
suitcase weights would be easier all around , if it can be done.
thanks for the replys
/ suitcase weights #5
pg 12 bottom right
/ suitcase weights #6
G'day as stated you will prob find there is not enough room to fit suitcase weights with a fel fitted as well. What have you got on the tph to make it so light in the front end?
Jon
Bell 500 Gallon Saddle Tank (A64119)
Bell 500 Gallon...
2008 SUBARU LEGACY 4 DOOR SEDAN (A64280)
2008 SUBARU LEGACY...
10000LBS Two Post Automotive lift (A64194)
10000LBS Two Post...
2022 FORD F-750 SUPER DUTY DUMP TRUCK (A63276)
2022 FORD F-750...
2022 EZ-GO ELITE...
2013 Ford F-350 4x4 Crew Cab Pickup Truck (A64556)
2013 Ford F-350...
