Suggestions Needed
/ Suggestions Needed #1
jay3534
zebulon nc
AC 5015
I need another tractor because my AC 5015 is too small for the six acres I just bought. There are older Fords and MF for sale in my area in my price range under $5000 but I don't know what to look for. Any help would be appreciated in what to look for.
Jay
/ Suggestions Needed #2
What exactly are you doing on that 6 acres? And what is the landscape like...........bare?, half wooded?........all wooded with a house?...........any outbuildings?
/ Suggestions Needed #3
You need to tell us what an AC 5015 is, how much weight, how much HP.........so we know where you are coming from.
/ Suggestions Needed #4
an AC 5015 is like a rider lawnmower sized SCUT
18hp, 15 ptohp.. about 1500# wet.
Depending ont he ops needs fo rthe 6ac. I'd say anything from a ford 6xx/8xx ( or rowcrop depending on the layout ).. up to a 2000 / 3000 ford.
again.. depending on needs..
/ Suggestions Needed #5
My thoughts exactly, that's why I asked about usage.
Usage will mowing 6 acres of mostly open pasture and blade for driveway which is 900 feet.
/ Suggestions Needed #8
getcha a good 600/601/800/801 4 or 5spd.. or 2000/4000 4 or 5spd, or 2000/3000 with a 4-6-8 spd
any of the above with PS will be nice.. but not a deal killer.
any of those will do a 5-6' rough mower.. obviously the larger engined ones are a lil more capable if using a 6' mower.. etc.
if going 65+.. get a diesel.. if 55-64.. get a gasser. JMHO
/ Suggestions Needed #9
Soundguy has some very good advice, but could I ask what tractors you've seen for sale in your area?
/ Suggestions Needed #10
There is a 4000 by me with a loader for 6500.00
/ Suggestions Needed #11
if a 4 cyl.. that's pricey.. if a 3 cyl, and in good condition.. not a bad price.. assuming manual gear tranny and not powershifting SOS...
/ Suggestions Needed #12
What do you know about a 445C?
/ Suggestions Needed #13
I know enought to direct you to ask RickB :)
I don't mess with the (new) industrials enough to TRY to tell you something.
I can read you specs off a sheet.. but that's not what ya want.. :)
/ Suggestions Needed #14
Just thought to ask your opinion on it as there is one for sale here and looks very clean. Not that I need another Tractor.
/ Suggestions Needed #15
ask rick for specifics.. but I havn't heard any 'bad' things about that model..
There are 8n's, a 601 / MF 135 and a 235's locally. Thanks for the replies
/ Suggestions Needed #17
Our first diesel Ford 3000 purchased the year they came out(mid 60's I think) was made in England and had no power steering. Great for straight rows when seeding row crop but you wouldn't want one if you were considering a loader. Our 600 series Ford and Fordson Dexta were fine without PS.
Cheers, Terry
/ Suggestions Needed #18
The problem with the 8Ns is they lack live hydraulics....it's a pain, or a two-stage clutch. The PTO shaft has to be turning to raise the implement. I've gotten stuck where I had to disconnect the PTO shaft so that I could raise the implement without turning the blades. The MF 135 and 235s are good machines.
/ Suggestions Needed #19
what's the info on the 601?
gasser?
what tranny?
condition?
price?
Ford 1962 601 Workmaster Tractor
4 Cylinder, 32 HP Diesel Engine
2005 MERCEDES CLK 500 (2) DOOR COUPE (A60430)
2005 MERCEDES CLK...
2000 TRANS CRAFT EAGLE SUPERBEAM (A60430)
2000 TRANS CRAFT...
Deere 410L (A53317)
Deere 410L (A53317)
2003 International 7400 T/A Heil 12 CuYd Dump Truck (A55853)
2003 International...
UNUSED INDUSTRIAS AMERICA EASY MAN TREE & POST (A60432)
UNUSED INDUSTRIAS...
2021 Takeuchi TL10V2-2 Track Loader with 76in Tooth Bucket (A61306)
2021 Takeuchi...
