Suggestions Needed
   / Suggestions Needed #11
if a 4 cyl.. that's pricey.. if a 3 cyl, and in good condition.. not a bad price.. assuming manual gear tranny and not powershifting SOS...
   / Suggestions Needed #12
What do you know about a 445C?
   / Suggestions Needed #13
I know enought to direct you to ask RickB :)
I don't mess with the (new) industrials enough to TRY to tell you something.
I can read you specs off a sheet.. but that's not what ya want.. :)
   / Suggestions Needed #14
Just thought to ask your opinion on it as there is one for sale here and looks very clean. Not that I need another Tractor.
   / Suggestions Needed #15
ask rick for specifics.. but I havn't heard any 'bad' things about that model..
There are 8n's, a 601 / MF 135 and a 235's locally. Thanks for the replies
   / Suggestions Needed #17
getcha a good 600/601/800/801 4 or 5spd.. or 2000/4000 4 or 5spd, or 2000/3000 with a 4-6-8 spd
any of the above with PS will be nice.. but not a deal killer.
any of those will do a 5-6' rough mower.. obviously the larger engined ones are a lil more capable if using a 6' mower.. etc.
if going 65+.. get a diesel.. if 55-64.. get a gasser. JMHO
Our first diesel Ford 3000 purchased the year they came out(mid 60's I think) was made in England and had no power steering. Great for straight rows when seeding row crop but you wouldn't want one if you were considering a loader. Our 600 series Ford and Fordson Dexta were fine without PS.
Cheers, Terry
   / Suggestions Needed #18
The problem with the 8Ns is they lack live hydraulics....it's a pain, or a two-stage clutch. The PTO shaft has to be turning to raise the implement. I've gotten stuck where I had to disconnect the PTO shaft so that I could raise the implement without turning the blades. The MF 135 and 235s are good machines.
   / Suggestions Needed #19
what's the info on the 601?
gasser?
what tranny?
condition?
price?
Ford 1962 601 Workmaster Tractor
4 Cylinder, 32 HP Diesel Engine
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2003 TRAIL KING TRI-AXLE BELLY DUMP TRAILER (A58214)
2003 TRAIL KING...
2020 DRAGON ESP...
DRAGON 500 BBL FRAC TANK (A58214)
DRAGON 500 BBL...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A57024)
NEW HOLLAND 706 30...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
iDrive TDS-2010H...
