Suggestions Needed
   / Suggestions Needed #1
jay3534
zebulon nc
AC 5015
I need another tractor because my AC 5015 is too small for the six acres I just bought. There are older Fords and MF for sale in my area in my price range under $5000 but I don't know what to look for. Any help would be appreciated in what to look for.
Jay
   / Suggestions Needed #2
What exactly are you doing on that 6 acres? And what is the landscape like...........bare?, half wooded?........all wooded with a house?...........any outbuildings?
   / Suggestions Needed #3
You need to tell us what an AC 5015 is, how much weight, how much HP.........so we know where you are coming from.
   / Suggestions Needed #4
an AC 5015 is like a rider lawnmower sized SCUT
18hp, 15 ptohp.. about 1500# wet.
Depending ont he ops needs fo rthe 6ac. I'd say anything from a ford 6xx/8xx ( or rowcrop depending on the layout ).. up to a 2000 / 3000 ford.
again.. depending on needs..
   / Suggestions Needed #5
My thoughts exactly, that's why I asked about usage.
Usage will mowing 6 acres of mostly open pasture and blade for driveway which is 900 feet.
   / Suggestions Needed #8
getcha a good 600/601/800/801 4 or 5spd.. or 2000/4000 4 or 5spd, or 2000/3000 with a 4-6-8 spd
any of the above with PS will be nice.. but not a deal killer.
any of those will do a 5-6' rough mower.. obviously the larger engined ones are a lil more capable if using a 6' mower.. etc.
if going 65+.. get a diesel.. if 55-64.. get a gasser. JMHO
   / Suggestions Needed #9
Soundguy has some very good advice, but could I ask what tractors you've seen for sale in your area?
   / Suggestions Needed #10
There is a 4000 by me with a loader for 6500.00
   / Suggestions Needed #11
if a 4 cyl.. that's pricey.. if a 3 cyl, and in good condition.. not a bad price.. assuming manual gear tranny and not powershifting SOS...
   / Suggestions Needed #12
What do you know about a 445C?
   / Suggestions Needed #13
I know enought to direct you to ask RickB :)
I don't mess with the (new) industrials enough to TRY to tell you something.
I can read you specs off a sheet.. but that's not what ya want.. :)
   / Suggestions Needed #14
Just thought to ask your opinion on it as there is one for sale here and looks very clean. Not that I need another Tractor.
   / Suggestions Needed #15
ask rick for specifics.. but I havn't heard any 'bad' things about that model..
There are 8n's, a 601 / MF 135 and a 235's locally. Thanks for the replies
   / Suggestions Needed #17
Our first diesel Ford 3000 purchased the year they came out(mid 60's I think) was made in England and had no power steering. Great for straight rows when seeding row crop but you wouldn't want one if you were considering a loader. Our 600 series Ford and Fordson Dexta were fine without PS.
Cheers, Terry
   / Suggestions Needed #18
The problem with the 8Ns is they lack live hydraulics....it's a pain, or a two-stage clutch. The PTO shaft has to be turning to raise the implement. I've gotten stuck where I had to disconnect the PTO shaft so that I could raise the implement without turning the blades. The MF 135 and 235s are good machines.
   / Suggestions Needed #19
what's the info on the 601?
gasser?
what tranny?
condition?
price?
Ford 1962 601 Workmaster Tractor
4 Cylinder, 32 HP Diesel Engine
2020 CATERPILLAR 299D3 SKID STEER (A60429)
2020 CATERPILLAR...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
Year: 2014 Make: Acura Model: MDX Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 183,948 Plate: (A59231)
Year: 2014 Make...
2017 TAKEUCHI TL10V2 SKID STEER (A60429)
2017 TAKEUCHI...
2012 MACK Tender Truck w/ADAMS Rear Discharge Bed Auger (A56438)
2012 MACK Tender...
40' High Cube Multi-Door Container (A53314)
40' High Cube...
