succumbed to fever
/ succumbed to fever #1
eteagle
Illinois
JD 3300
I'm now convinced that tractor flu fever is real. I've been browsing this post for a year and just went out and bought a JD 4300, rops, loader (430), R4 tires, HST, 4WD. I say "flu" because the fever you engender is contagious even over the web.
Any advice would be appreciated. I've been using a wonderful Ferguson TO 30 since l958 but am getting to old and skinny of butt to continue.
Is there any use for the mid PTO other than belly mower?
I will need rear ballast box but don't want to pay the JD price.
Would like to learn more about hydraulics. Other than loader, BH what equipment can I use that needs hyraulics?
By the way, on this groups advice, I visited over 12 local dealers. The starting price was 19K but within a month down to 18.1 with all dealers coming down to within $50 of each other. I really appreciate all the help.
Ernie
/ succumbed to fever #2
There are a couple of cheaper solutions to the ballast box.
If you go to www.wallacemfg.com you'll see something called a lift frame or some similar name. You could use that as a starting point for a ballast box of your own. They are sold at farm stores near me. Or you can buy a straight bar that connects across the lower links of the 3 pt hitch. Slide that bar through cuts in the sidewall of an appropriate container/form for concrete, such as a barrel. Put some concrete in, stick so rebar or angle iron etc in for reinforcing. More concrete, then insert a top link for the upper mount.
That should do it, I think.
BTW concrete weighs ~150 lbs per cu ft. A cu ft is ~7.5 gals. So a 55 gal drum is ~1100 lbs. You can scale down to other containers from there.
PS: What did Deere want for the ballast box?
-Don M
/ succumbed to fever #3
Ernie.
Welcome to the Land of Green .
Mid PTO can be used for a belly mower, snowblower, front mounted rotary broom, etc. Down here in Georgia, we don't have much need for a snowblower.
The hydraulics can be used for many things. We sell these tractors for golf course use and they have a long list of equipment requiring hydraulics. A few that come to mind are top dressers, coring aerators (Hyd top link), core harvesters, trailers (Hyd. dump), gang mowers, vacuums, and a multitude of others.
Holler at me if you have any problems with the tractor. That's what I do for my keep.
"Doc"
2011 Chevrolet Express 2500 Cargo Van (A61573)
2011 Chevrolet...
2015 Freightliner M2 106 AWD Altec DM478BTR Insulated Digger Derrick Truck (A60460)
2015 Freightliner...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A63688)
2019 Krause...
PALLET OF MISC METAL (A63291)
PALLET OF MISC...
JOHN DEERE BD1113 END WHEEL GRAIN DRILL (A63291)
JOHN DEERE BD1113...
UNUSED WOLVERINE PALLET FORK FRAME (A64281)
UNUSED WOLVERINE...
