Sub-soiler/Middle Buster
/ Sub-soiler/Middle Buster #1
demote
Georgia
Mahinra 2810 HST
I thinking of purchasing a combo sub-soiler/middle buster. link
My immdediate need is to bury some cable but it seems this combo unit would be useful. My question is will the middle buster serve as
a plow or am I misunderstanding the use of this implement?
I would appreciate any input. Danny
/ Sub-soiler/Middle Buster #2
I bought the plow version that is called by some a patatoe plow ( middle buster ) for cutting irrigation trenches and putting some drip irrigation lines underground. Turns out that we plan to try to grow a row or two of potatoes as well and might get to try using it for what it is intended for, digging potatoes out. Mine cost right at $100 out the door. I can sink the plow as deep as the tractor 3 point will let it go and cut a ditch with little or no load on the tractor. ( 33 HP ) Didn't get the hitch attachment or the subsoiler that went with the combo unit that was about $50 more. Already had a nice home made handy hitch for ball tow and couldn't figure out what I'd need the subsoiler for. Happy with the middle buster though, money well spent so far.
Chris
/ Sub-soiler/Middle Buster #3
IMO a middle buster won't serve as a plow, but it will tear up the ground (plow somewhat like when you see an oxen pulling a stick through the ground in undeveloped countries on TV).
The middle buster will toss some sod to the sides and leave a dirt trench. A plow will turn the sod over and lay it in the furrow, leaving roots and dirt showing on top.
Now granted, a plow not adjusted right will do about what the middle buster will do, but it's not designed to just root up the ground. /forums/images/graemlins/wink.gif
/ Sub-soiler/Middle Buster #4
I'm also considering buying a middlebuster to do some trenching, both for electrical conduit to my barn and for drainage. I like the price ($118) of this one at tractor supply much better! Tractor Supply Middlebuster
/ Sub-soiler/Middle Buster #5
For what it is worth, I bought the Howse combo unit from Northern Tool. It came with a sub-soiler, a middle-buster and a trailer hitch. The combo units had a system using 2 bolts to change the blades and their shafts. I removed the bolts and replaced them with top link pins so I could change implements without the use of tools (handy when you change things around a lot).
I modified the sub-soiler by drilling 2 holes in the trailing edge, using hose clamps to attach some plastic pipe and that turned it into a cable layer.
I also made up (help of my neighbor) a fork lift unit that mounts on the frame. I also used the frame to pull up about 350 feet of fence posts.
Here is a link to the modified sub-soiler Sub-Soiler & Cable Layer
Here is a photo of the whole unit with pallet forks Howse modified "do all"
I've also designed, but not welded up yet, a small tree/shrub toothed blade to rip them out of the ground. And a sod cutter to cut out strips of sod.
/ Sub-soiler/Middle Buster #6
Your soil type is the first consideration. I have the combo unit from Northern. I have hard adobe clay soil. Each will only drag across the surface. They should work in sandy loam. To work in my soil, I'd need to pile a ton of ballast on top and then have a 5 ton tractor pulling it. No exaggeration. You must first consider soil type and secondly the tractor weight and pulling ability.
/ Sub-soiler/Middle Buster #7
If you're not penetrating into clay, it may be the result of your top-link not being short enough. Bob Skurka and I have used subsoilers in pure clay - a hydraulic toplink is very helpful. Pull the toplink in very short to have the blade dig in, and then once it has "dived-in", lengthen it enough so you're not pulling your tractor into the earth.
For my needs, it may be that I really only need the middle buster but if the combo unit also can serve as a trailer hitch, I could make use of that as well. It's not mentioned on the Northern Tool website. There's a large Northern store in Atlanta (about 70 mi. away) if I could look at them but I suspect these items may be mail order only.
/ Sub-soiler/Middle Buster #10
Would said unit be helpful in shale, volutia type soil prior to discing a previously plowed/planted field? I'm thinking I could use one to get the soil "fluffed" up and allow more air to deeper reaches of soil. I imagine I'd pull the middle buster back and forth across my acre or two, then disc, then plant. After a hard winter and dead stuff being compacted, discing isn't real easy. I need to disc, wait a few days, disc, wait for rain, disc, wait a week, disc...etc. Getting old now with limited time.
/ Sub-soiler/Middle Buster #11
I'm going to use my sub soiler/ buster combo to lay a bunch of water supply hose soon so I'll be adding your attachment idea. Now I have an idea to run by you.
I'm going to need to dig footers for a 24x36 barn soon. I plan to use the middle buster to loosen the soil up about a foot deep. Then, take off the sub-soiler ripper and replace it with a 12x12" , 1/4 thick piece of steel, drilled. Bolt it to the sub-soiler assembly and use it to create my 12" wide footers. I'll still have to stop and dig out the dirt when it piles up, but it should work.
What do you think?
thanks, bw
/ Sub-soiler/Middle Buster #13
Gabby,
can you make any gentle turns using PVC, or is it strictly a straight pull? bw
Gabby, it looks like you have an eye-bolt tied to the sub-soiler. How are you attaching it to your pipe?
2021 UTILITY VS2DX 53FT DRY VAN (A59905)
2021 UTILITY VS2DX...
Unverferth RHD1645DG-36 Rolling Rarrow (A63116)
Unverferth...
2022 FORD TRANSIT 250 CARGO VAN (A59905)
2022 FORD TRANSIT...
2025 Greatbear Rachet Tie Down & Flatpack Tool Box (A61567)
2025 Greatbear...
2019 John Deere X380 Lawn Mower (A63116)
2019 John Deere...
2017 INTERNATIONAL LF687 DAYCAB (A63569)
2017 INTERNATIONAL...
