Stx 375 transmission code
/ Stx 375 transmission code #1
smiley53
crowley,louisiana
stx 375
I am having a problem with my STX 375. Whenever it is in drive the tractor will go back into neutral automatically. I then have to put it in park and back into drive and after going about twenty yards it will do it again. It started to throw a transmission code (56004) and it says that the measured transmission output speed does not match the commanded transmission output speed. What could be causing it to throw this code and what could I do to fix it?
/ Stx 375 transmission code #2
Is the speedometer working? I would check the output speed sensor.
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
GODWIN 6 HEAD PUMP (A65643)
GODWIN 6 HEAD PUMP...
2006 Heil DOT 406 Comp Fuel Tanker (A64194)
2006 Heil DOT 406...
2006 Heil DOT 407 Aluminum 9,000 Gallon Ethanol T/A Tanker Trailer (A64194)
2006 Heil DOT 407...
2017 Bad Boy Outlaw XP 60in. Zero Turn Commercial Mower (A64553)
2017 Bad Boy...
2025 Unused SDLGC80 Electric Golf Cart (A64194)
2025 Unused...
