stump/root killer
/ stump/root killer #1
otis whitehead
Houston,Texas
long agribuisness 45 hp
something i have been working on that i think a few of yall might like! A root knife/ stump puller. all hand made in the great U.S.A.
/ stump/root killer #2
Show us more detail. Tell us how you made it.
Looks great.
Clem
/ stump/root killer
I got the idea to make a root cutter to help cut ditches here on the property. The blade that i have would ride out of the cut on the roots. So i had some 1.25 inch plate that had been laying around.
/ stump/root killer
I notched the plate and the 4X4 3/8 thick angle iron so could weld both sides.(that first pic on the last post i think you can see the welds) After welding the plate to the angle iron i took a section of pipe and welded it to the plate and the angle iron. Then boxed the angle with a second 4X4 again full welds around the pipe and along all edges.Used 1/2 in plate and drill press to fab my plates for the pins and full pen welded them inplace.i am lucky i have a shop to work in that lets me use the big miller 250 wirefeed welders any time i want.
/ stump/root killer
If you look at the end of the point you can see a fatal flaw...A flat spot on the point. Didnt think that little spot would keep this chunck of iron from going into the ground but BOY WAS I WRONG. Ended up cutting a spade point on the end and now it forces itself into the ground like a plough.
/ stump/root killer #7
That's STOUT!! Looks like it does the job :thumbsup:
/ stump/root killer #8
Looks good. My thought is if you could have made it longer from the 3pt hitch so that you don't have the rear tires in the way for a larger stump?
/ stump/root killer #9
I use a subsoiler (similar idea) to cut roots & pull stumps (< 8") out and at first this tire/stump interference problem was a real show stopper. Whenever I wanted to drop the point to rip up the roots, one tire would start riding up on the stump & tipping the tractor over. So I started cutting the stumps off lower - a few inches above the ground - and that put an end to tippy tractor. Using the 3 point to pull straight up once you have hooked the stump really works unless there's a tap root to China.
2016 JCB 3CX 4x4 Loader Backhoe (A64194)
2016 JCB 3CX 4x4...
UNUSED WOLVERINE TDB-11-66W 66" BUCKET (A64281)
UNUSED WOLVERINE...
2020 DRAGON ESP 150BBL ALIMINUM (A60736)
2020 DRAGON ESP...
1994 John Deere 8300 (A64126)
1994 John Deere...
Landhonor Quick Attach Hydraulic Forks (A66285)
Landhonor Quick...
8ft. Teak Wood Table (A61574)
8ft. Teak Wood...
