Studs on Front Tires
/ Studs on Front Tires #11
My present configuration has 12" rims up front (as original) and as tires I have 12" used car that have studs installed.
(I used trailer rims with custom lazer cut centers to match the tractor hubs)
Used all last winter and to date not lost a stud.
Ratios match, that is front to rear, and so far I liked the performance, mind U with the loaded rears and 2 link ice chains the fronts do not have to work all that hard.
/ Studs on Front Tires #12
/ Studs on Front Tires #13
I have a Massey Ferguson MF1532 tractor that I bought new in 2012. My gravel driveway is about 1/2 km (about 1600ft) long and I get a fair amount of snow every year to clear. I had been using a Polaris Sportsman 6X6 with a 4ft blade for the last 13 years to clear the snow and that worked quite well but in heavy wet snow I could quickly run into traction problems.
So this fall I purchased a 7 foot quick mount snow blade for my front end loader. On the rear I keep a 6 foot "dirt" blade that I just use for pushing back snow in a straight line. The first few snow falls of the year were the nice light fluffy snow that doesn't have much weight. The new snow blade works really great for this. Recently however we have had some of the really heavy wet snow falls and that creates an issue for me. With the front blade angled to push the snow off to the right of the tractor I get into situations where the front of the tractor skids to the left even with my front wheels turned all the way to the right. This typically happens on areas where the ice is built up under the snow. I have carbide tipped studs on the rear tires and those are fantastic in icy conditions to drive the tractor forward. At the time I bought those studs I thought about putting some on the front tires too but the service guy recommended against it since he said the way the 4 wheel drive works is that the front wheels spin a little faster than the rear to "pull" the tractor. They are meant to slip a bit he said. So if I add studs to the front I am preventing this slip and placing a load on the front drive system that it isn't designed for.
Does that make sense? I don't want to do something that will damage the drive system but I imagine that better traction on the front wheels would certainly help or eliminate my sideways push issue.
Thoughts?
You could put any kind or amount of studs in your front tires that you want to.
Yes, they will increase the effectiveness of your front wheels.
By design most front axles have a built in amount of lead.
With studs on ice or snow pack you will not put as much load on the front axle as you do on a gravel surface in the summer.
Toro Reelmaster 6500 D (A61166)
Toro Reelmaster...
Adams Under Truck Conveyor (A61307)
Adams Under Truck...
Kubota SVL97-2 (A60462)
Kubota SVL97-2...
1995 Stoughton Enclosed Dry Van Trailer, VIN # 1DW1A5323SS900663 (A57453)
1995 Stoughton...
1998 JOHN DEERE 120 EXCAVATOR (A62129)
1998 JOHN DEERE...
2005 CASE 580 SUPER M SERIES 2 BACKHOE (A62129)
2005 CASE 580...
