Stuck with a BH92 backhoe I can't use
   / Stuck with a BH92 backhoe I can't use #71
Well, they were suppose to pick up the tractor Monday to do the install, when no one showed up or bothered to call I figured there was a problem. To make a long story short still no bracket, Kubota told me now its between me and the dealer. So I am going to rent a trailer and go pick it up Saturday and try my hand at installing it. I think a machine shop should be able to make the bracket fairly easy. Thanks, hopefully this is the end of the saga.
When looking at your paperwork did you pay for the mounting kits? Or did you buy a tractor "with backhoe"?
   / Stuck with a BH92 backhoe I can't use #72
As Yogi Berra said, "This is like deja vu all over again."
   / Stuck with a BH92 backhoe I can't use #73
OP, sorry to say you are still being screwed by your selling dealer. DON"T get a shop to 'make up a bracket'. Go down to your dealer and INSIST they remedy this immediately, and find out what they plan to do to make it right. If they keep stroking; get on the phone with the zone rep and get it solved. This IS ridiculous!
I agree that Kubota wouldn't likely kick a new customer to the curb over this and tell you to remedy it between you and dealer; especially since the dealer has been LAME since day 1.
   / Stuck with a BH92 backhoe I can't use #74
What is answer to tomseller question on purchase paperwork? Is the mount kit mentioned.
Looking at it, the paperwork isn't really broken down, just has BH92 backhoe for $10,393 and lists the tractor and front loader. It must have the subframe, bucket and thumb added in. I do have the subframe all mounted except for the brackets. Here is what Kubota has to say, basically the dealer needs to order the brackets or another subframe, yeah no kidding. :)
   / Stuck with a BH92 backhoe I can't use #76
I am sure you can look up the mount kit on Messicks website get the bracket part number. That might move things along with Kubota and the dealer. Maybe worth a try anyway.
Thanks Pat, I will try again and see if I can find it. I decided I'm done worrying about it, I don't need the stress at my age. I'm going bring it home and if nothing else get it out of the weather until I can put it together. I really do think the dealer is trying, just can't seem to get the darn part.
   / Stuck with a BH92 backhoe I can't use #78
Here's what I would do.
Buy the part from Messicks or another Kubota dealer, regardless of cost.
Pay someone local (preferably a competing Kubota dealer) to install it, fit the backhoe and test everything out
Sue their ***** in small claims court for every cent it cost
But BEFORE you do that, I'd recommend reading this:
Writing A Demand Letter That Gets Results
A 'demand letter' is a wonderful tool that I have employed to get companies to do what they should know to do anyway. It is a clear way to spell out what the agreement is, what is expected, what you've done, what they've NOT done, and what WILL happen starting now. Include sales contracts, cancelled checks (copies), receipts, detailed phone records and other records of contacts and visits to the dealership. **This is basically all the evidence you would / will show to the judge in small claims court** Send it registered mail and wait for a quick phone call.
I used this tool on a contractor who was quite reluctant to finish the job and I had a phone call within a few hours and a tractor trailer full of equipment at my property the next day. 48 hours after the ink dried on the letter, PROBLEM SOLVED.
Don't give up the control you have over your own situation. Their responsibility is to make things right. If they choose not to, YOU make it right and make THEM pay for it. Very simple concept.
I wish you luck, good Sir.
   / Stuck with a BH92 backhoe I can't use #79
No offense meant, BUT, you are being WAY too easy on the dealer, and, or Kubota. THIS IS TOTALLY UNACCEPTABLE. You know what you bought... WHY DON'T YOU HAVE IT ??? Reverse engineering that bracket is asking for trouble... Sorry, this is my opinion.
   / Stuck with a BH92 backhoe I can't use #80
Agree with others, don't modify yourself, dont take delivery. If nothing else, get refund from dealer for bh and buy elsewhere. who is your dealer?
2019 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2019 Ford F-150...
1995 FORD LT9000 DUMP TRUCK (A51222)
1995 FORD LT9000...
2007 TRANSCRAFT 48X102 FLATBED (A50854)
2007 TRANSCRAFT...
2018 INTERNATIONAL 4400 4X2 EXT CAB SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
CAT FORKS W/ QUICK COUPLER (A50854)
CAT FORKS W/ QUICK...
2011 Liebherr L586 (A51039)
2011 Liebherr L586...
