stuck in float
/ stuck in float #1
mya
b2410 kubota
kubota la352 loader stuck in float pos, just had detent rebuilt for this reason any help appreciated
/ stuck in float #2
Sounds as if the person whom rebuilt the float control on hyd valve didn't perform that task correctly & should try again!
/ stuck in float #3
On mine I take the cap off the end of the position with the float, and clean things off. If you don’t use your float often, tiny bits of debris will deposit and gum things up. When I first bought my tractor used, the guy I bought it from had never tried to put it in float. So the first time, I brute forced it inot float, it stuck there. Took me about five minutes to take off the cap and clean things up, and clean out the cap with a bit of brake cleaner.
Put it back together, gave a hard pull on the Joystick, and it came free. I use the float fairly often, and haven’t had an issue since.
And be sure to change your hydraulic filter often, at least once a year, regardless of the hours. the stuff gumming the float up was an ultra fine metal powder.
Rake Master CR-72G (A64119)
Rake Master CR-72G...
2013 HINO 338 26FT BOX TRUCK (A59905)
2013 HINO 338 26FT...
429858 (A61165)
429858 (A61165)
2012 KOMATSU PC360LC-10 EXCAVATOR (A64279)
2012 KOMATSU...
2020 WIRTGEN WR200 XLI SOIL STABILIZER (A62129)
2020 WIRTGEN WR200...
2021 Kubota SVL75-2 Track Loader (A63689)
2021 Kubota...
