Stripping Screw Heads
/ Stripping Screw Heads #1
DrRod
Platinum Member
Ellicott City, MD - Farm in Orbisonia PA (south ce
John Deere 4110
This is one of those general irritant things but . . .
When I use my drill to screw in screws, it almost always results in stripping the slots out of the screw heads. I'd like to blame the cheap screws from the big box stores but maybe its the design of the drill mounted screw drivers or the speed of the drill or must my poor technique. Does anyone have a suggestion on how to limit this irksome outcome?
Thanks
/ Stripping Screw Heads #5
Square drive or Torx drive screw heads are the only way to go with screws. The only time I buy Phillips head drive is if neither the Robertson or Torx is not available and then only with the shorter screws. Not only do the screw heads strip out but the Phillips head drivers wear out rather fast also and contribute to the stripping of the screw head due to improper fit. Phillips head are much improvement over the single flat screw and the Robertson and Torx are double the improvement of the Phillips over the flat.
/ Stripping Screw Heads #6
If your drill has torque settings, turn it down until it is just enough to put the screw in. That has cut down the number of stripped heads for me.
/ Stripping Screw Heads #7
When I changed from a drill to a 1/4" impact driver, I found that I stripped far fewer screws and found driving screws a lot easier. Now that I have been using one for 4 years, I will never go back.
/ Stripping Screw Heads #8
ditto!!!
/ Stripping Screw Heads #9
I agree. I was given a set with a drill and a impact driver. The drill has been used ~15 times in ~2 years, the impact driver? Hundreds of times.
Aaron Z
/ Stripping Screw Heads #11
A drill motor without a clutch is not for driving screws. Doing so will be nothing but frustrating.
I'm a big fan of the impact driver, too. A couple handymen and I put together a 40 x 72 steel arch building with a couple of small cordless impact drivers...over 10,000 5/16" bolts.
/ Stripping Screw Heads #13
Take a look at your bit.
Use cheaters if your eyes are old or you have "long arm disease" like me.
Is it the right size - snug fit - or sloppy fit or worn?
Set your speed control or torque control.
Counter bore your pilot hole to a clearance depth x diameter size for the screw's shank
I keep a wax (parafin) candle in my drill tool box.
A swipe of the wax over the threads and I can lower the torque by 3 or 4 clicks.
This greatly reduces "cam-out" of the bit.
/ Stripping Screw Heads #15
Combination of junk soft screws and junk soft bits.
Ditto on the quit using phillips.
I like torx better than square, but both are vastly better than phillips.
Just did a deck with all T25 torx. 12x32 deck and about 15lbs of screws total. All on the same 2 torx bits that the two drills started with. Not a single stripped screw either.
/ Stripping Screw Heads #16
Thanks
I use torx head screws always now phillips was ok for awhile beat the heck out of flat head but no where near as reliable as torx. :thumbsup: (I never had any luck at all with square fwtw probably worse luck with it than cheap phillips ymmv as always)
/ Stripping Screw Heads #18
In the uk we use Philips head a lot, torq bits & others seem to be more specialist.
I've just completed a deck with specific deck screws that had a weired head to them, like a rounded Philips with a specific bit supplied with them - great fit - to the point the bit would stay in the screw when you moved the drill away!!
I tried Milwaukee impact driver bits & found them terrible! Cracking, rounding etc. def not buying them again.
/ Stripping Screw Heads #19
When I use my drill to screw in screws, it almost always results in stripping the slots out of the screw heads. I'd like to blame the cheap screws from the big box stores but maybe its the design of the drill mounted screw drivers or the speed of the drill or must my poor technique. Does anyone have a suggestion on how to limit this irksome outcome? Thanks
Phillips screws are like a socket set. They come in different sizes and shapes. Using the correct driver with the correct screw equals almost always success. When I was building a 24X40' deck I came to realize not all phillips heads are created equally. Using a drill with the wrong head will disappoint you many times. Some have mentioned square heads. Yes they are superior but square heads are not installed EVERYWHERE. -kid
/ Stripping Screw Heads #20
I'm working on getting any none-Torx (star) screw out of my shop because I have come to believe. In a normal cordless drill, I "pulse" them in. And I buy bulk packs of the drivers (the #25 Torx last a lot longer than the #2 philips) but when I sense any slippage at all, I change it out for a new one. Quality screws cost much more than a driver bit.
Mahindra 4550-4L Loader (A64911)
Mahindra 4550-4L...
2019 Chevrolet Tahoe SUV (A66738)
2019 Chevrolet...
2015 Freightliner M2 106 Ambulance (A66736)
2015 Freightliner...
2016 Chevrolet Express Shuttle Bus (A66736)
2016 Chevrolet...
2020 Gooseneck 6'x16' Livestock Trailer (A64912)
2020 Gooseneck...
Giyi Mini Excavator Attachment Set (A64912)
Giyi Mini...
