Stripping Screw Heads
   / Stripping Screw Heads #1
DrRod
Platinum Member
Ellicott City, MD - Farm in Orbisonia PA (south ce
John Deere 4110
This is one of those general irritant things but . . .
When I use my drill to screw in screws, it almost always results in stripping the slots out of the screw heads. I'd like to blame the cheap screws from the big box stores but maybe its the design of the drill mounted screw drivers or the speed of the drill or must my poor technique. Does anyone have a suggestion on how to limit this irksome outcome?
Thanks
   / Stripping Screw Heads #5
Square drive or Torx drive screw heads are the only way to go with screws. The only time I buy Phillips head drive is if neither the Robertson or Torx is not available and then only with the shorter screws. Not only do the screw heads strip out but the Phillips head drivers wear out rather fast also and contribute to the stripping of the screw head due to improper fit. Phillips head are much improvement over the single flat screw and the Robertson and Torx are double the improvement of the Phillips over the flat.
   / Stripping Screw Heads #6
If your drill has torque settings, turn it down until it is just enough to put the screw in. That has cut down the number of stripped heads for me.
   / Stripping Screw Heads #7
When I changed from a drill to a 1/4" impact driver, I found that I stripped far fewer screws and found driving screws a lot easier. Now that I have been using one for 4 years, I will never go back.
   / Stripping Screw Heads #8
ditto!!!
   / Stripping Screw Heads #9
I agree. I was given a set with a drill and a impact driver. The drill has been used ~15 times in ~2 years, the impact driver? Hundreds of times.
Aaron Z
2012 INTERNATIONAL LF687(INOPERABLE) (A50854)
2012 INTERNATIONAL...
2022 FORD F-150 XL EXT CAB TRUCK (A51406)
2022 FORD F-150 XL...
2015 Freightliner Cab & Chassis (A47384)
2015 Freightliner...
HUNTER SYSTEM 700 TIRE BALANCER (A50854)
HUNTER SYSTEM 700...
2015 Ford F-250 Ext. Cab Knapheide Service Truck (A50323)
2015 Ford F-250...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
