Stringtrimmer Q
/ Stringtrimmer Q #1
Cord
Richfield, Wi
Resident Architect
I have a Echo straight shaft 21cc string trimmer. I'm trimming along the riverbank and have come into a clump of Purple Lustriffe. The stuff is decorative flower which is quite agressive. The plant gets to be around 5' tall and has a stem that's around 3/8" at the base. The stem isn't woody, but it's very tough. So tough that the .095 string won't cut through it. If I let the string chew at the stem it will topple the plant but the string breaks very frequently. I'm thinking that I need some type of brush blade. I bough a three tined flingy blade from my local big box. The blade has a scalloped metal (not plastic) edge with a plastic shank. According to the owners manual I can get metal blades for my trimmer. I went on ebay and found several different types of metal blades. Most of them seemed to be based around the sawblade concept with varying tooth counts. I could see the metal blade working very well on the Purple Lustriffe, but what tooth count? Should I go for more teeth or fewer? Will the existing flingy cutter that I have work?
/ Stringtrimmer Q #2
</font><font color="blue" class="small">( Should I go for more teeth or fewer? )</font>
The blade with more teeth is to fell saplings ie wood. They make around an 8 tooth blade that's more for heavy weeds and grass.
/ Stringtrimmer Q #3
Not familiar with your plant, but I have had great luck with the metal blades that have chainsaw style teeth in them. I tried the table saw looking blades, and had little if any luck. Shindawa makes a blade with either 6 or 12 chain saw teeth and they will wack through anything in a hurry. And, if you are half way decent at filing a chain saw chain, you can sharpen these blades yourself. Several on the forum use something similar called a "Beaver" blade, I believe. It has many more teeth than the Shindawa. I haven't tried them side by side, but I can guess that they would last longer between sharpenings, but also, more teeth can sometimes increase cutting resistance. I found the Shindawa blades at my John Deere dealer. Anyone who carries Shindawa trimmers should have them.
213137 (A64276)
213137 (A64276)
3268 (A63117)
3268 (A63117)
2019 RAM LARAMIE 1500 (A65643)
2019 RAM LARAMIE...
New/Unused Mini Quick Attach Auger with Bit (A65583)
New/Unused Mini...
2022 JOHN DEERE 333G SKID STEER (A65053)
2022 JOHN DEERE...
CHANDLER 10' STAINLESS STEEL FERTILIZER SPREADER (A64277)
CHANDLER 10'...
