Straps vs chains - trailering
   / Straps vs chains - trailering #1
CMV
Platinum Member
NC
Kioti NX4510HST (previous LS XJ2025H, JD 500C)
I don't trailer my tractor often but wonder if ratchet straps are sufficient/safe or are chains necessary?
Pretty light at maybe 2300 lbs for the tractor w/ FEL + any implement. Trailer is a typical landscape/utility with a reinforced mesh back gate and rail all around. 2x 3500 lbs axles, electric brakes, bumper pull. F150 ecoboost w/tow package pulls it.
I like CGU/1-B aircraft tiedown straps. I keep them stored indoors when not in use and they are in great shape. Is there any reason those aren't acceptable and I should be using chains & binders instead? 4 x 5000lbs straps * 50% means that should secure 10,000 lbs & I'm maybe 1/4 of that.
In general, I go from my land to my house which is 10-15 min trip. For that, I can't see taking the extra time with chains when the straps are so much faster. But I can see lending a hand on some family projects 6.5 hrs away, all highway, going thru several states and would want to be safe and legal for a longer trip like that (not meaning I DON'T want to be safe & legal for a short local trip...).
   / Straps vs chains - trailering #2
Those straps are used to tie down 2000lb bombs as well as nuclear cruise missiles to weapons trailers for transport. You’ll be fine. LOL
Thinking of all the big stuff I've ridden with in C-130s, C-141's, & C-5's secured with them that's kinda what I'm thinking, but figured I better get some input. :)
Not that my machine is huge by any means, it's a lot more than the typical riding mowers or ATVs I generally haul around.
   / Straps vs chains - trailering #4
Do they have a load rating label a DOT inspector can see?
Bruce
   / Straps vs chains - trailering #5
The straps are fine but I found they don't last as long as chains. They do get frayed in places. Personally I use 4 chains and ratchet binders for the tractor and either chains or straps for attachments.
   / Straps vs chains - trailering #6
I have dedicated chains, cut to the right length for front and back. I can actually put them on as fast as straps.
   / Straps vs chains - trailering #7
For infrequent use and lighter loads I find straps are far more useful and convenient for me. I have only been stopped and weighed once while hauling my 2400H and the state cops did not seem concerned about me using 3" ratchet straps on four corners.
   / Straps vs chains - trailering #8
I prefer chains, but if you can protect the straps from fraying they'll be fine.
   / Straps vs chains - trailering #9
   / Straps vs chains - trailering #10
But if not marked, the rating from the chart is often considerably lower, just like for chains.
Bruce
2008 Ford Escape XLS SUV (A55853)
2008 Ford Escape...
2018 Chevrolet Impala Premier Sedan (A55853)
2018 Chevrolet...
2016 Cat TL1055D Telehandler (A55315)
2016 Cat TL1055D...
2017 Ford F-550 Crew Cab Enclosed Service Truck w/ Liftgate (A56858)
2017 Ford F-550...
2011 Isuzu NPR 14FT Box Truck (A56858)
2011 Isuzu NPR...
2010 Ford Crown Victoria Sedan (A55853)
2010 Ford Crown...
