Chains Straps or Chains (or is this too personal?)
   / Straps or Chains (or is this too personal?) #51
Re: So where do you run them? *DELETED*
Post deleted by Gary_in_Indiana
   / Straps or Chains (or is this too personal?) #52
OK, Von... You're just showing off with those clean, shiny chains and binders now. /w3tcompact/icons/smile.gif
I'm under the impression the 10,000 lb. rated straps have at least a 4,700 lb. WLL, but I could be mistaken. I know that 5,000 lb. rated straps have a WLL of 3,300 lbs. If the percentage holds true, then the 10,000 lb. rated straps would have a 6,600 lb. WLL.
   / Straps or Chains (or is this too personal?) #53
Gary, You may be right, I'm just going by the Northern catalog. In there the 10,000lbs. straps have a working load limit of 3300lbs. But It could just be the brand that they sell has that rating. Yours may be way different. But I still like my shiny chains, and new binders!/w3tcompact/icons/smile.gif
   / Straps or Chains (or is this too personal?) #54
I like to weld the tractor to the trailer, then encase the entire loaded trailer in concrete. It is a very secure setup, with the benefit of no frayed straps or rusty broken chains.
   / Straps or Chains (or is this too personal?) #55
I use chains.
   / Straps or Chains (or is this too personal?) #56
Yamaben:
Do you have any trouble with weight restrictions? And what do you use for a tow vehicle, a semi tractor?
   / Straps or Chains (or is this too personal?) #57
Sounds like you guys better read the other post that has digressed to a discussion of CDL requirements.
   / Straps or Chains (or is this too personal?) #58
Cat, D12 /w3tcompact/icons/smile.gif
   / Straps or Chains (or is this too personal?) #59
Seriously-I have always kind of wondered something about securing a load on a trailer. Maybe this is a dumb question, but is a chain (or strap) double in strength if it is looped around the loaded object and tied back at its starting point? Does that method have more tensile strength than one strand of tie down attached end to end?
   / Straps or Chains (or is this too personal?) #60
<font color=blue>is a chain (or strap) double in strength if it is looped around the loaded object and tied back at its starting point? Does that method have more tensile strength than one strand of tie down attached end to end?</font color=blue>
Yup,
According to my Mechanical engineering Handbook, Force = Weight/number of ropes. two ropes gives 1/2X force or for a given force (strength of rope) 2 ropes = 2X Weight.
If you remember back to physics class, and do a free body diagram, the answer becomes more clear. You can have force F in each rope, if two ropes are going from the load to the tiedown point, then you just doubled your load capacity.
2014 MAGNUM PRODUCTS LIGHT TOWER COMBO (A58214)
2014 MAGNUM...
2019 Merlo TF 42.7 (A60462)
2019 Merlo TF 42.7...
Zero Turn Mower (A59231)
Zero Turn Mower...
2016 Ford F-550 Venturo HT40KXX 3 Ton Crane Mechanics Truck (A59230)
2016 Ford F-550...
John Deere 5100M (A53317)
John Deere 5100M...
Freighliner Tender Truck (A56438)
Freighliner Tender...
