Strange PTO behavior.
   / Strange PTO behavior. #11
Mine doesn't. The BH will freewheel for a couple minutes after shutdown. There is an overspin clutch, about it I think.
   / Strange PTO behavior. #12
jeffmazz said:
Doesn't the PTO have a wet brake? When you disengage the PTO the brake slows the implement down so it doesn't free wheel.
I'm guessing that when you disengaged the PTO the brake engaged and brought your already slower spinning blades to a screeching halt.
Just my .02 cents.
Jeff
Jeff is right… You can see this by trying to turn the pto when it is not engaged… it will only turn about a half turn.
Also hydraulic, live-independent has nothing to do with the main clutch… it is independent. KennyV
   / Strange PTO behavior. #13
Just a last followup after some hogging this weekend. I can shut the tractor down, blade spinning, disengauge the pto and nothing happens. BH still spins but I think the overspeed clutch stops clicking.
Now this is with the tranny in neutral, if it's in gear I think something would make a clank. But then the whole tractor might want to move.
UNKNOWN 500BBL WHEELED FRAC TANK (A58214)
UNKNOWN 500BBL...
KBH Tender Trailer (A56436)
KBH Tender Trailer...
2022 Carry-On 5'x8' Trailer (A53316)
2022 Carry-On...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Toro (A56857)
Toro (A56857)
Land Pride RCR1260 (A53317)
Land Pride RCR1260...
