Stick welding questions
/ Stick welding questions #1
Jim_in_Omaha
Omaha area
LK3054
I know there are tons of post regarding welding, but I thought I might ask for some direct pointers on a couple of things. I have experience with MIG which is fairly straight forward. I needed more heat so I found a Miller Thunderbolt XL 300/200 AC/DC that I picked up for $250. It had been dropped and I fixed the cabinet and cover, it was brand new. I have found that it is capable of producing plenty of heat.
What I would like some tips on are this:
Welding mild steel 1/4 to 1/2 inch thick ranges. What would the best type of rods be for this?
I have some 1/8" 7014 I bought at TSC for practicing and it seems to be real touchy on the amperage. Sometimes I make a great bead, then other times it looks like I smear toothpaste. This is after I clean the slag off. Also it would appear that the direction of the welding is touchy. If I keep it horizontal and flat it does considerably better.
I have been using DC neg and that seems to be the best results. I've been studying the other posts and have picked up alot of good tips. Most of my stuff is done with my Millermatic 135 but it's only good up to about 1/4. Maybe someday I can pickup a Millermatic 251. /forums/images/graemlins/smile.gif
thanks
Jim
/ Stick welding questions #2
Why not ask on the Miller/Hobart sponsored discussion board? Many experts there including factory support people.
Welding discussion board
/ Stick welding questions #3
I try to use 7018 whenever possible. This is the same rod used for pressure vessels and structural. It's a great multi-position rod. The only problems are that the metal needs to be free of rust (easily accomplished with an angle grinder) and the rods need to be kept dry (they absorb moisture from the air).
The other rod I use is 6013 or 6010. The 6013 is a low penetration rod and great for thin metals. The 6010 is similar to the AC 6011 but is for DC service.
/ Stick welding questions #4
gsganzer: Great advice!
jim: As for the 'smeared' effect you're seeing it might be technique or arc blow. Its hard to say which from what you wrote. When you get this situation do you notice the arc moving around the path of travel?
/ Stick welding questions #5
I almost always use 6013. It's about the easiest rod I've ever used. Most of the stuff I build is over-engineered and over welded, so strength of the rod has never been an issue (poor welding skills has, but that's another story).
/ Stick welding questions #6
RonR, I like the 6013 myself. It's a good general purpose rod. I think the 7018 is easier for vertical up and overhead (both positions I hate) as it seems to "freeze faster" and have a lower tendency to run out.
I'm thinking of making a rod oven to keep the 7018's so they stay dry.
/ Stick welding questions #7
Well,
From another angle
7014 I believe is fast fill fast freeze.
If I was advising someone starting out, I would say,
With todays quality of rods etc. flip your machine to AC
6013 rod for neat clean appearing welds, primarily on clean material
6011 rod for higher penatration more structurally sound welds or for overcoming rusty metal etc.
And remember that welding is a skill that is honed through practice. More stick time will yield better results.
(I would reccomnend the 6011 and 6013 over the others (7018 or such) as they are more common, generally less expensive, and are not as finicky to run.
/ Stick welding questions #8
Thanks gsganzer.
I'll buy a pound of 7018 and try it. I don't weld enough, I just get it at TSC in the plastic couple pound boxes. In the 80s, I split a BIG box of rod with a guy, and I've just now run out of it!
Take care,
Ron
I think I'll pick up the small boxes of 6011, 6013 and maybe a 7018 to practice with. I was told to try the 7014 and I can see the fast fill fast freeze character.
Thanks
Jim
/ Stick welding questions #11
I use all three and my general preference is for 7018. It's a superb fill rod too. I too use a little Millermatic MIG but get the ARC out for more penetrating demanding welds. I have researced larger MIG units like Millers 251 and Lincolns 300. My next MIG will be a Lincoln, I would suggest you try one, they have really, really done some research in an area where I always thought Miller was King.
/ Stick welding questions #12
</font><font color="blue" class="small">( I have experience with MIG which is fairly straight forward.)</font>
If you're a pusher, you push your puddle and work it instead of pulling it or dragging it I have another option.
Lincoln makes a rod called 5P+. Their regular pipeline E6010 is a red colored flux rod called 5P. The 5P+ is a grey flux rod. It's also an E6010 rod but it's not the same. They act a lot different.
For me the red rod cuts hard like a regular any brand E6011. I find they cut more than they fill. And working the puddle isn't as easy as I find with the 5P+. 7018 and 6013 are what I call runny rods. You're getting more material into the weld than you're cutting. So it's less about working the puddle and more about directing it.
A case in point. Vertical welds I like to up. I can do them down but I'm more comfortable with the joint's strength and construction. Sometimes I've used 6013 because it leaves such a pretty bead when it's done properly. I don't have the skill to do 6013 up. Barely have the skill to do 7018 up and have it look good.
An old weldor told me how to do 6013 down. He said to crank up the machine fifteen amps more than I thought appropriate. Start the arc, turn my head, and drop my hand. It works. You can do 6013 down and if you're hot enough and move fast enough the flux won't have time to get into the bead.
With 5P+ I find that I'm cutting just right and also getting in just the right amount of filler to have a comfortable puddle to work with. I think if you have mig experience you can relate to what I'm saying. There's this point where the heat and the wire speed are just right. For me the 5P+ has the wire speed adjusted just right if I have my heat right on.
The other thing that's nice about 5P+ is it cleans up easy. I use knot brushes on small angle grinders. I usually have three angle grinders at any welding situation, shop or truck etc. One with the knot brush, another with a grinding disc, and the last one with a Tiger disc or generic replacement.
My father taught me to weld using 6011 on sixteen gauge galvanized fence tubing making gates. If you're seeing a puddle you're a milisecond late and you already have a hole, big hole. But I learned to work the puddle.
We'd bought a small gas drive (portable welder) and I was doing some work on a ranch in trade for feed for a calf. One day one ton showed up with a flat bed all framed out but not decked.
Naturally I walked over and inspected the welds. They were like rows of dimes. I was totally blown away. I didn't know how anyone could have that kind of control. I knew what I wanted to learn how to do.
Some time later I decided to take a gravy course while using up my VA education benefits. I first took a gas welding class. I loved it. In fact if it's possible I believe everyone should first learn gas welding. That way no matter what kind of welding you do you know what's basically happening.
Then I took the arc welding class. First night the instructor gathers us around. He lays down two prepared coupons (pieces to practice with) and explains what he's going to do with the 6013 rod. We flip down our hoods and he does it. Then he taps the coupon with the hammer and the flux falls off. It's like a row of dimes.
"That cheatin' SOB" came out of my mouth before I could stop myself.
BTW I have two migs and and two stick machines, one is a gas drive. It stick two inches of weld for every quarter inch of mig.
/ Stick welding questions #13
As a certified all position welder I would recommend getting a box of 7018 and using then as they are a high strength low hydrogen rod. However they are an A.C. rod. Weld using a drag technique with the rod at around a ten degree angle. Try to keep arc short to avoid arc blow and wandering. It may take a while to get the hang of it, but in my experience this usually produces the best results. Find some scrap metal and concentrate an keeping the puddle at first, then move up to a weave pattern. Keep in mind that it is possible to weld 1/4 to 1/2 plate in a single pass but that requires a heavy rod and alot of amperage. Most of the time you'll get better results using a 3/32 to 5/32 rod and doing multiple passes in a fillet joint on thicker metal. Remember to tack weld to ENTIRE joint about every 8 to 10 inches to help avoid welding draw and clean ALL the slag out as it will contaminate and weaken the weld. Good luck and I hope this helps.
/ Stick welding questions #14
<font color="blue">As a certified all position welder I would recommend getting a box of 7018 and using then as they are a high strength low hydrogen rod. However they are an A.C. rod. </font>
DragonsBane,
I think you meant DC rod for the 7018...
Trouble with the 7018 is the moisture issue, for guys like me who are hobby welders and may not have a project going to use up the rods. And may not have an oven to keep them dry...hummm...another project, I wonder... /forums/images/graemlins/smile.gif
Those 7018 sure are easier to make a pretty bead with than the 6010s, at least for like me who don't do enough welding to get real good at it...not that my 7018 beads are pretty, just prettier...than the 6010s are... /forums/images/graemlins/blush.gif
/ Stick welding questions #15
</font><font color="blue" class="small">( I think you meant DC rod for the 7018...)</font>
They have A/C E7018 available now for those who only have A/C machines. /forums/images/graemlins/grin.gif
7018 is sometimes referred to as "farmer's friend" because it can be used on tool steel and as a hard surfacing medium.
It does make a pretty bead.
/ Stick welding questions #16
<font color="blue">Trouble with the 7018 is the moisture issue, for guys like me who are hobby welders and may not have a project going to use up the rods. And may not have an oven to keep them dry...hummm...another project, I wonder...
</font>
Henro a friend of mine acquired an old refrigerator that someone had set out on the curb for junk. He cut the wires to everything but the internal lamp and wired it so that it was always lit. It was small wattage but that closed box with the light bulb generated enough heat to keep his rod dry and warm. He said it really helped with his welding. /forums/images/graemlins/cool.gif
/ Stick welding questions #17
One of the guys I worked with at a maintenance place for Fritolay inc had his tool box set up and had built a small side box which had a light bulb in it and left it on all the time. this was the welding rod sotrage for him. made a world of diffferance when talking the shop was usually about 90% or better in humidity year round! was really bad in summer there 110 deg F and 98% humidity! floors would get slimy orm the oils & grease even after constant cleaning and they used a grease desolving solution which would turn the stuff into slime that was harder to walk on than anything I've ever seen! lots of slip& falls, usually not many injuries though cause we all had a nice layer of padding from all those delisous chips HOT off the frier! (don't get me wrong the place aws cleaner than MY kitchen!) just a really big building is harder to keep clean even with full time cleaning people!
Mark M /forums/images/graemlins/laugh.gif
/ Stick welding questions #18
<font color="blue"> Henro a friend of mine acquired an old refrigerator that someone had set out on the curb for junk....He said it really helped with his welding. </font>
PineRidge,
I can relate to that! My old fridge holds beer kegs...can't say that helps much with my welding though, now that I think about it... /forums/images/graemlins/grin.gif
/ Stick welding questions #19
My buddy took a old coleman cooler drilled a small hole for the wires and used a small 12volt light plugs it in to a 12 volt hook up in his truck for when he goes to job sites he uses it a great deal in the winter. you could use a small X-mas light too the space is small the cooler does not take up much room in the shop, that is if you don't buy bulk. His will hold two tins or more if you take them out of the box. just my 2 cents /forums/images/graemlins/grin.gif
/ Stick welding questions #20
I've found small freezers work great. One of the problems is using good appliance bulbs or replacing others frequently. I'm using about fourteen cubic foot one now, have been for about ten years.
2025 Swict 78in Bucket Skid Steer Attachment (A61572)
2025 Swict 78in...
24Wx25Lx12H Two Car Metal Garage | Durable Metal Garage
24Wx25Lx12H Two...
1994 Chevrolet C70 Kodiak 18FT Box Truck (A61573)
1994 Chevrolet C70...
KOMATSU FORKLIFT (A63291)
KOMATSU FORKLIFT...
KIVEL 3500 PALLET FORK ATTACHMENT (A61572)
KIVEL 3500 PALLET...
2006 Cadillac Superior 6-Door Limousine, Ultra-Low 20396 Miles (A63689)
2006 Cadillac...
