stick welder question
/ stick welder question #91
Well, I confirmed today that there is indeed 250v to the shop. There is also a ground wire attached to a buried rod out there. Correct me if I'm wrong but I need to do two main things along with a host of other safety checks. Get a 2 pole 30 amp breaker for the shop and gang together the two 30 amp breakers in the house. Should be good to go. Now I can get some kind of Everlast welder if indeed I can ever be gotten back to. (2 emails and a pm with no response)
Arrow, I haven't gotten said emails. I did see the pm, and sent a reply...at least I thought I had. I'll go back and look for it and either resend it or do a new one.
/ stick welder question #92
Arrow, you have NO IDEA how relieved you just made me, thanks for the clarification of your intent...
Also, you've just been contacted by the man Everlast needs to find maybe 20 MORE of - Mark.
He'll treat you right, if Everlast doesn't kill him off first. They seriously need more manpower like Mark, who is a FAR better weldor than I'll EVER be, and at least as nice/helpful as me :D Steve
/ stick welder question #93
Yup, Two pole breaker, or "listed" handle ties. It sounds to me he has a neutral, Is it connected to the neutral buss in his house sub panel? Is his house sub panel fed with 4 conductor cable? Does he have separated neutral and grounding busses in this house sub panel? As answers aren't forthcoming, he says he isn't qualified to rectify problems, and I suspect he has quite a number of hazards, I would like to see a qualified electrician look it over. Not all electricians are ogres who rob people blind. I bet his car gets maintenance more often than 30 years. In fact I bet he has replaced his entire car a number of times in thirty years. Some of the knob and tube developed by Westinghouse 100 years ago is still in use, and compliant with code. I don't feel newer wiring methods have as long a life. Get it checked out!
You say it sounds to you as he does have a neutral, Please explain. If he has 2 insulated wires and one bare grounding wire going to his shop and 240v, where is the neutral for the 120v circuit?
/ stick welder question #94
He has one bare grounded wire or neutral.
In some cases NAEC does not require that a neutral be insulated. I would need to do more research to confirm that 30 years ago it was or wasn't acceptable to use the bare conductor as a neutral. The requirement for a grounding conductor is recent. 30 years ago the requirement was two "hot" insulated conductors and a neutral or grounded conductor. I'm a little vague whether it was then required to be insulated. No grounding conductor was then required. In that day we routinely ran three THHN conductors in conduit to a garage. At the garage it was treated as a house, 3 insulated conductors. We grounded at the garage as we do at the house even now. I'll look for older code books, the oldest In the office is 1999. The old ones are in the cellar.
1999 code appears to require insulated neutrals with exceptions, (in article 230-22,30, and 41) as part of multiconductor cables, in services overhead, underground, or service entrance cables. The conductors we are discussing are part of a feeder. Article 225-4 Exception addresses overhead feeders. If 1999 code exempts feeders underground from insulated neutral requirements, I haven't found it.
While I still don't know where this bare conductor is connected at either end, it must be functioning as a neutral or grounded conductor, 120V loads wouldn't work. I believe the lack of insulation on it is where the most difficult to rectify violation exists.
The worst shock of my life was from a bare, dead, overhead service neutral. A remote home with no other transformers within a mile had a power outage, line fuse had blown. In my mind there was no power in the area. Working on the damaged neutral, I became the conductor from the transformer center tap which was bonded to high voltage ground conductor. The entire electrical grid sought to reach ground through my right hand, through my body, out the left and on to earth via the home's grounding system. I couldn't let go! Brain said let go, hands wouldn't respond. My feet did work, I was able to back away and pull off it. Forearm muscles were sore a long time! I've been more careful since!
Chandler Equipment 18' Litter Spreader (A60462)
Chandler Equipment...
2008 BOBCAT T320 SKID STEER (A62129)
2008 BOBCAT T320...
20 X 20 CAR PORT (A58214)
20 X 20 CAR PORT...
2018 Trail King Lowboy (A61307)
2018 Trail King...
Giyi GY-TB47 Telescopic Forklift Boom (A60463)
Giyi GY-TB47...
Freightliner Tender Truck - Adams Tender (A61307)
Freightliner...
