step down connectors
/ step down connectors #1
Megawisdumb
Montevallo, Al
LX2610HSD, Z251, BX25D
I put a Kencove PD80 on my Kubota BX25 today and all was well until I went to plug in the hydro. The driver controller has two 1/2 npt lines and a 3/4 npt return line. I made a custom adapter in the hydro res for the 3/4 npt that fits snug but I can’t find any 1/2 thread with 1/4 connectors for the male & female connectors. Anyone know where these can be acquired? Probably should have seen this prior but the thrill of pounding some post instead of my auger with a tapping rod was alluring and distracted my common sense for a few days.
/ step down connectors #2
You're probably going to have to use couplings and bushings to get from the 1/2" to 1/4" Be sure to use hydraulic fittings and not just iron plumbing fittings on the pressure side. Curious how this works out. Looks like a lot weight up high for a little tractor. Are you going to be able to pick it up high enough?
/ step down connectors #3
Not exactly sure of you problem but there is a whole host of hydraulic plumbing fitting that may solve you problem...
Great links...thank you. However, I have yet to find a 1/2 female to 1/4 male so I can place my Kubota 1/4 quick connect on it. On the weight question, it carried it much better than my heavy heavy bush hog. If I can solve the step down issue I'm ready to pound some posts.
I did find this on Amazon...we shall see.
/ step down connectors #7
Think I would prefer steel.... 1200 PSI may be less than you hydraulic system is capable of... And then there is the price factor...
Your BX should be putting out about 2000 PSI so go with the steel fittings.
Roger...steel it is. Thanks folks. I'll update with some photos when I pound a few 6 inchers into the ground.
This worked out way better than I anticipated. Slammed about 25 6" posts in a few a few hours. Still have a few hundred left... Took between 15-20 slams to put the 8 footer at shoulder height. Now I just need to find a 1/4 spliter so I don't have to keep plugging the supply line to the pounder and back to the 3 pt to move to the next hole. I'll never use an auger again...
What is the difference between a selector valve and a diverter? I do see I can get a diverter in 1/4 which matches by quick connectors. I am tired of plugging in the pounder and 3 pt every 10 mins!
Parker BV3D04N1SS1N Manual 3-Way Diverter Valve 1/4 NPT "L" Port Steel​
2017 Kia Rio Sedan (A61574)
2017 Kia Rio Sedan...
213064 (A64276)
213064 (A64276)
2007 Dodge Ram 1500 4x4 Crew Cab Pickup Truck (A61573)
2007 Dodge Ram...
(1) 7.2-16 TIRE W/ 6 LUG RIM (A64280)
(1) 7.2-16 TIRE W/...
2016 GMC SLT 3500 Pick Up (A62613)
2016 GMC SLT 3500...
2019 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61573)
2019 Chevrolet...
