Step bumper hitch
/ Step bumper hitch #1
8NTX
Rowlett, TX
Ford 8N, Ford 850
Has anyone used a drop-down box hitch attached to the step bumper of their truck? There are several manufacturers that make these; they attach to the existing holes on most step bumpers. The existing bumper hitch (by simply placing a hitchball through the hole) on my 2004 F-150 is rated at 500 lbs. tongue weight and 5000 lbs. max trailer weight. My tractor on my flatbed and boat w/trailer both max out at about 3600 pounds. Of course, the existing step bumper is too high and I need it about 4-6 in. lower. Seems like overkill to put on an expensive Class III hitch when the step bumper is already rated as much as I need.
/ Step bumper hitch #2
It may be overkill, but I don't care much for bumper hitches. If it was me, I'd even forgoe the Class III and get a Class 4.
Please read disclaimer before any one tries to fry me again in regards to towing.
DISCLAIMER; The above opinions are only Johnday's, and reflect his own ideas on safety. Your opinion may differ.
/ Step bumper hitch #3
I've put class 3 receiver hitches on my last 3 vehicles, they aren't that expensive, ($75 - $125 has been my experience). With the $125 hitch being an OEM dealer ordered hitch. I'd avoid the bumper mount for anything more than a utility trailer.
/ Step bumper hitch #4
Putting a drop down hitch on your bumper will put much more stress on the bumper than just the ball. You can get a Class III hitch installed for around $150-200. It's a drop in the bucket compared to a $30,000 truck. IMO, a good receiver hitch is not overkill, it's a necessity.
/ Step bumper hitch #5
I had a 1990 F150 with the factory step bumper that was also rated for 5000 lbs, while I did install a drop down box hitch that attached to the bumper, it was only used for a utility trailer that weighed less than 1500 lbs. loaded.
Ford clearly stated in the owners manual that the 5000 lb. rating was considered void if any type of additional bracketing was added to the factory bumper. I would advise against adding the drop down box hitch as the majority of the ones I have seen are rated for only 3500 lbs. or less. When I needed to tow a travel trailer, I purchased a Reese Class III receiver hitch that cost me about $80 brand new. The truck cost me $7000 used, and if I had a brand new $30,000 pickup I'm darned if I would try to save a few bucks buying a low rated hitch.
Buy the receiver mount, it's cheap insurance and if you ever need to tow a really heavy trailer, your receiver will be capable of using a weight distributing hitch.
/ Step bumper hitch #7
I picked up a Reese class III/IV hitch for under $100 at Walmart for my '01 F150. 30 minutes and a floor jack you're ready to go (no drilling). The model specific hitches are a little more money, but easier install (no shimming).
/ Step bumper hitch #8
I put one of those on my T100 a few years ago. Didn't use it for a lot of weight (maybe 1400 # max, usually less than 1000). After about three years, with a lot of use on poorly graded roads, I noticed the bumper had some vertical play--welds holding it on had broken. I immediately had a frame-mounted hitch installed. Works a lot better. Found a good one on line for $100 to install on the wife's new truck a few weeks ago.
/ Step bumper hitch #9
That type of hitch isn't ideal, but they work just fine if not overloaded. That's what I had on my old '81 F250 on the farm, and I never had a problem pulling a 16' trailer with the B2710 on it.
/ Step bumper hitch #10
Don't want to hijack this thread but a quick question.....I have an 01 Chevy S10 and would like to wire in a trailer connector and wonder if there is anything that hooks into the existing wiring ??? I don't want to have to cut & splice, etc.etc.
Thanks
Eric
/ Step bumper hitch #11
Yes Eric,
Go to almost any do-it-yourself auto parts or a TSC or even Wal-Mart. Separate your connectors in the rear and plug it in.
Made by Hoppy, costs $19.95 at Auto Zone if you have one close
/ Step bumper hitch #12
</font><font color="blue" class="small">( Don't want to hijack this thread but a quick question.....I have an 01 Chevy S10 and would like to wire in a trailer connector and wonder if there is anything that hooks into the existing wiring ??? I don't want to have to cut & splice, etc.etc.
Thanks
Eric )</font>
Most vehicles, including my 2000 S-10 has the wiring harness up inside the left side frame rail. All you need to do is wire an end plug to it.
/ Step bumper hitch
JC Whitney sells a step bumper box hitch that is rated at 500 lbs. tongue weight and 5,000 lbs. trailer weight, the same as the step bumper. E-mailed the co. that makes the hitch, and of course they state that in no way will this hitch alter the tow capacity of the bumper if properly installed. But, after looking at the measurements of the hitch and the mounting holes, I've decided it won't fit my truck and have decided to get a Class IV mounted by the local hitch store.
/ Step bumper hitch #14
My FORD factory installed RECEIVER hitch on my F150 is rated for 5000 lbs and 500lb tongue weight in weight carrying mode. I was suprised. No different from the bumper that came installed.
Does go up to 7000lbs and 700 in weight distributing mode.
Check your ratings on your receiver hitches - you too might be surprised.
/ Step bumper hitch #15
First let me place a strong vote for the Class III or better yet IV receiver hitch. A load that heavy needs brakes also and should be on both tandem axles even if your state only requires them on one. Many newer trucks are factory wired for a brake controller that should just plug in under the dash.
Regarding trailer wiring, auto parts stores and others that sell a variety of hitches also sell a plug-in adaptor for "popular" truck models that just plugs in series with the existing wire harness that feeds the truck tail/brake lights.
This type of adaptor usually is only the basic 4 or 5 wire type for lights only and is not set up for use with electric brakes. You may need another adaptor for trucks that have separate amber turn signals and red brake lights to function with a trailer with standard combined brake & turn.
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
East Texas Gooseneck Trailer (A65563)
East Texas...
Deere 700K (A64126)
Deere 700K (A64126)
POULAN 44" VINTAGE 2 MAN CHAINSAW (A64276)
POULAN 44" VINTAGE...
Rhino 12ft Blade (A63688)
Rhino 12ft Blade...
2023 JOHN DEERE 550P LGP CRAWLER DOZER (A65053)
2023 JOHN DEERE...
