STEINER 430 MAX, Samurai Sickle Mower Experiment is a BUST!
   / STEINER 430 MAX, Samurai Sickle Mower Experiment is a BUST!
If you ever tried to dig into a pile of whatever with the 430 MAX, using the slip-scoop, 200 lbs would be believable. Poor little critter!
   / STEINER 430 MAX, Samurai Sickle Mower Experiment is a BUST! #23
Did you mean 2000?
That is what it said on their site at Samurai.... under questions and answers 3.3 GPM and a min of 200 lb. of pressure....could be a typo...... jim
   / STEINER 430 MAX, Samurai Sickle Mower Experiment is a BUST! #25
I know it seems low to me too, but the flow rate seems normal. I don't think a 1/4" hose will carry the volume needed..... they do show a Ventrac with one but it is used with a loader that has its own pump and tank and it is driven off the PTO.... jim
   / STEINER 430 MAX, Samurai Sickle Mower Experiment is a BUST! #26
Not what I meant. Seems some people could never get themselves to report any negative aspect about what they own.
I paid a fair bit for this and feel a bit dupped. I don't need to protect any pride to say that.
I don't recall any sickle being anything other than basically flat. Only the vegetation to go between the knives and get sheared. Not sure about any other guard. I will have to find a sickle mower and look at it for comparison.
Just wanted to let you know that you are not sailing this ship alone. I too have bought a Samurai sickle bar. It has been a great disappointment from minute 2 of ownership. As soon as I put the cutter to work it jammed. The teeth crossed over and the hydraulic motor stalled out. Cleared jam, cut branch , jam, repeat. Teeth will sometimes just break and continue operate. I probably have less then a hour of operation on this unit with 90% of the teeth destroyed. I had lost of back and forth with tech support. at the end of it they sent me a set of teeth no charge. However this did not solve the problem. with new teeth installed i was not able to manually move the sickle back and forth without the teeth colliding. This is when i removed the teeth only to find that they are bent. I can only assume during the manufacturing of the teeth that they where distorted. At some point the teeth where ground flat because you are able to see the marks. maybe the heat treating of the teeth or the plating caused the warpage. The whole unit seems to be made of very thin material. I now find myself making reinforcement parts to make this a more robust cutter. Hope something works out soon.
Sorry to hear of your troubles. Aside from the low flow of the Steiner 430, which is not the sickle mowers fault, the unit did work as manufactured, just the blades did not hold up and were not suitable for such a wide range of vegetation as indicated.
I was hoping that they would offer me blades, AT LEAST AT A DISCOUNT OR COST. No such offer!
   / STEINER 430 MAX, Samurai Sickle Mower Experiment is a BUST! #28
I don’t know much about Steiner or Ventrac machines. But if they do have a front pto, I wonder if you could somehow convert/mount an old Farmall Cub or Super A sickle mower to work? Those old tractors do not have much horsepower. So a modern Steiner or Ventrac should have adequate pto hp.
They have a front belt driven PTO. If a guy had all the time in the world and some resources, he could build almost anything I guess.
   / STEINER 430 MAX, Samurai Sickle Mower Experiment is a BUST! #30
Get an old Haban Sickle bar mower they are belt driven and mount it in front of a Ventrac...... jim
I have seen one, in many, many years, and it was sold. BUT WAYYYY more money than I would spend, especially given it's dinky reach. At least with the hydraulic model, you can custom mount it out as far as you like.
   / STEINER 430 MAX, Samurai Sickle Mower Experiment is a BUST! #32
They are 4' and I saw them for a couple hundred dollars and they use guards and good sickle bar, sounds better than this hydraulic that self destructs ....... jim
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
WOLVERINE PT-16-01C 3PT HITCH ADAPTER (A60432)
WOLVERINE...
Mower King Brush Cutter (A53317)
Mower King Brush...
2436 (A60432)
2436 (A60432)
2020 Westfield MKX 100-83 Auger with Swing Hopper (A61307)
2020 Westfield MKX...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
