steering wheel nut, MT180D
/ steering wheel nut, MT180D #1
tnjind
Indiana
Can anyone tell me what size the nut is that holds on the steering wheel on my MT180D?
Thanks.
/ steering wheel nut, MT180D #2
How tall are you? How much do you weigh?
Haha, you funny.
Thanks for the info, very useful..........
/ steering wheel nut, MT180D #4
I'll get my S-470 Buck parts manual out in the morning and see what it says. Most likely the same size.
/ steering wheel nut, MT180D #6
My parts manual was not a lot of help. It shows: M1 20.
OK, thanks for looking.
Well I lost steering today and had to tear apart the box, what a mess. So.....anybody know what size steering wheel nut is?
Also any tips on the box rebuild?
/ steering wheel nut, MT180D #9
The nut on my steering wheel is an M23. Do you have a manual?...it should have a steering section. There are 2 different designs and which one used was dependent on it being 2 or 4 wheel drive.
Hmm, this one appears to be closer to a M12, I need to bring my thread gauge home from work. The manual I got with the tractor may show it, if I can find it.
It is 4 wheel drive. I bought this thing a few years ago for I think $500. It was in a garage that burned down around it. Lots of little problems. No plastic or wiring left on it. It even melted the aluminum pistons in the loader cylinders. But it does run and works.
Update,if anyone cares.
The balls in the steering box, the recirculating balls, all came out which caused the loss of steering. The box was full of water and the lower bearing was frozen.
I ordered 5.5mm balls, bearing and shaft seal from McMasterCarr.
I cut off the threaded portion of the shaft that holds on the steering wheel and tig welded a 1/2-13 threaded portion of a bolt to hold the wheel.
All good now I mowed a 1/2 acre yesterday.
So far, so good.
Now to address the blowing batteries up problem.
/ steering wheel nut, MT180D #13
I know that I'm a bit late but just located my parts manual for MT180,180D and it shows nut item # 25 to be PN A503 0114 001 to be M14
Now you know!
/ steering wheel nut, MT180D #15
Looks about right, gets the job done. Thumbs up.
2009 Landoll 435A 50ft. 43 Ton T/A Tilt Deck Equipment Trailer (A60460)
2009 Landoll 435A...
2019 Dodge Durango SUV (A61574)
2019 Dodge Durango...
2022 Ford Explorer AWD SUV (A61574)
2022 Ford Explorer...
JOHN DEERE 7420 TRACTOR (A63291)
JOHN DEERE 7420...
H&H 100 GALLON ALLY WAY SPRAYER (A63291)
H&H 100 GALLON...
2019 CUSHMAN HAULER PRO ELECTRIC GOLF CART (A58375)
2019 CUSHMAN...
