Apr 1, 2024 / Steering issue #1 A angelo47 New member Joined Apr 1, 2024 Messages 1 Tractor Power trac pt -425 Power trac pt 425 2002 Problem is have to turn steering wheel alot with sluggish or no response to wheels to turn Can any one help with this issue?
Apr 1, 2024 / Steering issue #2 ponytug Super Member Joined Mar 27, 2007 Messages 9,135 Location Bay Area, CA Tractor Power Trac PT1445 angelo47 said: Power trac pt 425 2002 Problem is have to turn steering wheel alot with sluggish or no response to wheels to turn Can any one help with this issue? Click to expand... Welcome! Can you share a few more details? Do the lift arms work? Does this do it always? Did it start gradually, or...? High /Low throttle? When was the hydraulic oil suction filter last changed? Have you ever changed the hydraulic oil? All the best, Peter P.S. putting your location in helps.
Apr 3, 2024 / Steering issue #3 woodlandfarms Super Member Joined Jul 31, 2006 Messages 6,155 Location Los Angeles / SW Washington Tractor PowerTrac 1850, Kubota RTV x900 95% of the time it’s your steering cylinder seals worn out. The other 5% is either your pump or steering valve.
