Steel Buliding Decaying!!
   / Steel Buliding Decaying!! #1
chado613
Kingston, Ontario, Canada
IH 624, IH B414, Kubota RTV 900, Kubota M7060
Has anyone had any experience with this?
Is it repairable? or does the whole piece need to be replaced?
   / Steel Buliding Decaying!! #2
Have you had any salt blocks or mineral blocks in there? Mine did that when I had horses many years ago and had a mineral block for them to lick on. Happened quick too.
I believe the previous owner use to salt the around the entrance to that building
   / Steel Buliding Decaying!! #4
All building material, wood or metal, should be 6" above the grade. A few solutions would be to install a PT "skirt board" around the perimeter (a 2X10 or 12). This would allow you to cut the siding up (above grade) about 6-8" and install a horizontal trim (J channel or rat guard) and this new 2X would be your new fastening point for the siding & trim as well as a closure between the building & the ground.
Another solution would be to do the same thing at the bottom, but cut the siding up at the next wall girt and using a different accent color to replace the lower damaged piececreating a "wainscott" look and dressing things up a little. This also makes for easy future repairs at this area that is veunerable to damage.
   / Steel Buliding Decaying!! #5
Good ideas Rusty... yeah looks like salt corrosion.
   / Steel Buliding Decaying!! #6
Was something behind the panel piled up against it? It looks like stuff is falling out of the building...
   / Steel Buliding Decaying!! #7
You can easily cut it off with a cutting disk on a 4 1/2 inch grinder and then slide a longer piece under it that is about a foot longer. Shouldn't take very long or cost very much
It's actually the insulation coming out of the bottom. Thanks for the advice fellas I am going to give it a try
   / Steel Buliding Decaying!! #9
Make sure to paint the cut edge where the bare steel is exposed ... ;)
JOHN DEERE CP 770 (A53084)
JOHN DEERE CP 770...
Vermeer BC1800A Wood Chipper (A51573)
Vermeer BC1800A...
2024 Bintelli ActivEV Pulse Electric Golf Cart (A51694)
2024 Bintelli...
(10) Replacement Thumb Cylinders (A51573)
(10) Replacement...
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
