Std. or HD pallet forks?
/ Std. or HD pallet forks? #22
Have to agree with LouNY.
Not just lift capacity spec but durability using. With a tractor picking un-palleted loads like equipment, logs rocks etc puts lots of stress on the forks.
Depends on where the weight rating is done.
/ Std. or HD pallet forks? #23
For $85 dollars and 5 pounds of weight I would go with the HD, yes your current tractor would be just fine with the lighter duty ones but if you ever upgrade or even just borrow a heavier tractor sometime or just for reselling down the line the HD would sell easier.
I agree - in 5 or 10 years you decide to get rid of them for some reason the $85 dollars extra you paid will make them worth $100 more in the used market and the HD model opens up your sale to a LOT more buyers.
/ Std. or HD pallet forks? #24
I've been shopping for SSQA pallet forks for my new Kioti CK2610... lift capacity "in excess of 1800#" according to the Kioti website...
I can almost promise I'll never approach the max lift... I don't move downed trees, buy pallets of stove pellets, stack and move firewood or any other such thing... I'll be organizing my other implements on pallets, moving lawn furniture on a seasonal basis, carrying a 15 gallon spot sprayer... pretty much all light-duty stuff...
I've come across many "light duty" forks in the $500-600 range... unfortunately shipping is a killer, in many cases fully a third of the total delivered price is freight charges... (for personal reasons I'd like to stay away from Titan Attachments... happy TA owners, please forgive me...;))
I've pretty much settled on Express Steel forks... Made in America, reasonably priced and, most importantly, REASONABLE SHIPPING COSTS... (thanks to member "NYONE" for the ES recommend!)...
ES has two models: "Standard" which have a 4000# capacity, weigh 305# and cost $740 delivered...
Second option is "Heavy Duty" 6600# capacity, weigh 310# and cost $825 delivered...
For my purposes, the biggest difference, other than the price, is the HD model comes with a forged and machined top rail, the Std model has a "bent steel" top rail... either will work for what I'm planning...
I tend to look to the future... when it's time to move on and sell whatever implements I've accumulated over time...
The HD model seems a "no-brainer" to me... am I missing something?
Personally - I would get nothing but the HD set - I had a LD set but quickly realised the need for the HD set - you will never exceed them that way - the fault with the LD set was with the horizontal upper mount bar, weight of wood box filed bent the bar - does not even come close now that I have the HD set
/ Std. or HD pallet forks? #25
For that money I would swallow my pride and go to Titan light duty free shipping $337 or some ebay seller.
I bought some clamp-on Titan forks. The clamp screws bent in the first use. But I had a fab shop make up a clamp assembly with 1" bolts, and it works well now. Still reasonably cheap. The custom fab work cost me $100.
/ Std. or HD pallet forks? #26
I would use express steel . 13 percent off through today. I have been happy with their products
/ Std. or HD pallet forks? #28
Std. or HD pallet forks? This will solve your problem, quit over thinking what your tractor can do. I have a similar clamp on set for my Kubota L2600 and they can do the job provided you can tighten them down good and then give them a whack with a hammer. OH ! did ya see the FREE shipping ?? Best of luck with your decision.
/ Std. or HD pallet forks? #29
If you're looking at your resale price, you'd get more for the HD, but you're paying more to get them. So in the end, your gain/loss will be about the same.
/ Std. or HD pallet forks? #30
Ebay maker/seller sold me a pair of, as you all describe, clamp on forks. My tractor is small, Mahindra 2516, and my fork limit is 800lb. My reason for commenting is to express how useful these are. I leave mine on all the time. It makes it easy on me to take down the trash can 400ft to the road. Much better than rolling it. I bought them to assist in the process of our move-in and they really did assist. They assist with everything around here. I do not remember how much I paid for them, but whatever it was, it was worth it. I have never had any regret about getting these. You will find it will be true for you too.
/ Std. or HD pallet forks? #31
Used forks are pretty rare in my neck of the woods. I think when people get them, they keep them forever.
Used forks here cost more than new.
/ Std. or HD pallet forks? #32
Many years ago I bought a set of forks - can't remember which company but I got the name on TBN. Were supposed to be fine for my tractor. I'm not sure if the weight limit was stamped on the forks. They may have been used on a tractor with more lift capacity than the Kubota L5740 for which I bought them when the top slide hook - the part welded to the top of a fork that grabs the top rail - failed and dumped that side. Nothing was deformed - just a failed weld. I'd get the HD myself (I now have 10,000# and 4,000# forks) but also keep an eye on stress points.
/ Std. or HD pallet forks? #33
Resell on HD will be better!
/ Std. or HD pallet forks? #34
After owning one for 5 years you can't go wrong at this price. I added two 42 inch forks to my making it useful for short and long pickups.
/ Std. or HD pallet forks? #35
You seem to have your mind set on the QA forks, which are nice, no question there. For your stated use however, a set of clamp on forks would serve you just fine, and come in at less than $200. Money saved could be used for another implement down the road.
/ Std. or HD pallet forks? #36
Having had clamp-on forks and now Q/A forks, I would never buy clamp-ons. Yes, they are ok, so is a rake to do leaves, but a large Stihl backpack or a 3pt rear blower is better. The Q/A will allow you to do more - I can easily slide a load sideways with the side of my forks to line something up, the bolts on types don't do well if you don't get things straight on for example.
You seem to have your mind set on the QA forks…
Actually, it’s bigger than that…
I have a mindset of making things easier in the future… easier on my worn and tired body…
Originally I was looking at a 3 point pallet fork for my MF135… to be used as I described earlier (moving simple, light items)…
Then Mother Nature visited us with a deluge which washed away part of a ”land-bridge” on our property… I tried rebuilding it with the Massey and my box blade… which was difficult at best and wasn’t really working as I had hoped… that’s when Julie and I decided it was time for a tractor with a FEL…
Having a modern tractor not only means I can more easily maintain our property but it also allows Julie to operate the machine…
QA means I dont Have to lift, twist, adjust or fasten the forks to my bucket… I’m sure they’d work fine once I had them connected but, to be honest, for me, the thought of attaching individual forks has me thinking… upfront money is “cheaper” than a visit to a chiropractor…:ROFLMAO:
/ Std. or HD pallet forks? #38
One of my dumber ideas was to buy a set of used forks off somebody’s Bobcat. Seemed like a bargain at $400. Heavy as hell and the standard skid steer mount would work (I thought) on the Great Bend loader on my Kubota.
First, all skid steer mounts are not the same. I had to torch cut off excess metal along the sides, plus the useless Bobcat steps. Next, the d&#n thing had lived a hard life and had a slight twist in it. The bottom rail is bulged and heat and a sledgehammer still haven’t got it completely straight.
In retrospect, I would gladly have spent $300 more for a brand new set.
/ Std. or HD pallet forks? #39
I have the ones S854 pictured, and I like 'em just fine.
Since you asked, I'd go with the lighter duty ones, or some other lower cost option rated for more than your tractor.
Tuppence is tuppence.
/ Std. or HD pallet forks? #40
Heavy Duty and long forks are the ONLY way to go. A friend and I purchased Quick Attach pallet forkes 10 years ago. Through the years here are some of the other uses. Digging trenches or stumps out; lifting, moving all types or materials or implements, without pallets. My friend drilled a 3/4" hole in the end of one fork so he could use it to hookup and push wagons. He also made a platform so he could stand on to work instead of a ladder/scaffolding. My son used mine to rip out a set of concrete step and side walks. The uses keep expanding as we build/remodel things on the farm. These 2 sets are still true and functional; no welds. Yes shipping is $$$$; we drove 250 miles to get these. Remember you only get what you pay for and are you truly satisfied until you have the best?
2018 Tycrop Vector Belt 22ft. VB-16H Portable Sand Belt Conveyor (A64194)
2018 Tycrop Vector...
2018 Bell B30E 30 Ton Articulated Dump Truck (A64194)
2018 Bell B30E 30...
2015 KUBOTA F3990 MOWER (A66091)
2015 KUBOTA F3990...
1994 Peterbilt 377 T/A Sleeper Cab Truck Tractor (A64194)
1994 Peterbilt 377...
Man Basket Boom Lift Attachment (A64553)
Man Basket Boom...
2010 Chevrolet Express 3500 Dive Team Cargo Van (A64556)
2010 Chevrolet...
