Status of Everything Attachments
   / Status of Everything Attachments #1,301
I bet Ted will be wearing an orange jump suit and sandals with grippy socks!
   / Status of Everything Attachments #1,302
Isn't the ground still on the bottom, neutral is the T slot?
Electrical wire contains three wires.1. White-2.Black 3. Bare Wire or Green wire.
When using electrical wire to wire a wall receptacle one places the black wire on the brass screw, the white wire of the shiny screw and the bare or green wire on the brass neutral safety screw.
One then connects the black wire to the single screw on a circuit breaker in the main breaker box. One then connects the white wire to the grounding bar built into the breaker box. (there are usually two in the breaker box) The bare wire (no insulation or covering) or green wire to the other grounding bar in the breaker box.
This wiring procedure is recommended by licensing officials to prevent injury or death. Because a break in connectivity occurs when plugging in an electrical cord into a receptacle box more often than one thinks.
So the round neutral ground is an added layer of safety. It was not intended to replace the function of the white ground wire or the large plug hole in the receptacle box. The large ground spade connector on the plug and the female orifice on the receptacle are/is still the primary ground.
A “break” in the neutral line occurs a lot more often than you think. In fact, a “temporary” break in the neutral happens all the time. Think about it… when you stick a 2-pronged plug into a receptacle, do you think the neutral always makes contact first? Nope - the hot and neutral prongs are the same length. So when you plug something into an outlet, 50% of the time the hot makes contact before the neutral! This means there will be a time span (typically a few tens of milliseconds) where only the hot is making contact at the plug/receptacle, and not the neutral. If the neutral were connected to the chassis, and you happened to be touching the chassis while sticking the plug in the receptacle, you’d get zapped (assuming you’re grounded).
So how do we get around this problem? By running a third wire that connects between earth ground and the chassis. In addition, we make the ground prong longer than the hot and neutral prongs. That way the chassis is connected to ground before the other two are connected.
A “break” in the neutral line occurs a lot more often than you think. In fact, a “temporary” break in the neutral happens all the time. Think about it… when you stick a 2-pronged plug into a receptacle, do you think the neutral always makes contact first? Nope - the hot and neutral prongs are the same length. So when you plug something into an outlet, 50% of the time the hot makes contact before the neutral! This means there will be a time span (typically a few tens of milliseconds) where only the hot is making contact at the plug/receptacle, and not the neutral. If the neutral were connected to the chassis, and you happened to be touching the chassis while sticking the plug in the receptacle, you’d get zapped (assuming you’re grounded).”
On a kitchen sink, Cold water is on the right. Hot water is on the left.
In a wall receptacle ground is on the left, (white wire)primary voltage is on the right (black wire) neutral safety ground (round hole bottom) bare or green wire.
Only two thing you have to remember about electricity.
1. You cannot see it
2. It will kill you
3. This is what will make electric cars dangerous. People don’t understand 1 and 2 and they are smarter than the engineers that designed and built the electric car so they modify it and start a fire that burns the house down.
   / Status of Everything Attachments #1,303
Don't leave out many older plugs are not polarized... the plug will go in to the receptacle either way.
I still see old washing machines with no plug with the third prong ground.
These were to have a separate wire from chassis to to cold water pipe...
Don't forget old electric 240volt ranges with a 120 volt convenience outlet built in...
   / Status of Everything Attachments #1,304
I know you are all trying to be funny with the off topic posts in this thread, but damn, you are really doing a severe disservice to anyone new to this thread who had unresolved issues looking for more solid information about EA. Just my opinion, of course.
   / Status of Everything Attachments #1,305
It is just that there really is nothing happening with the EA story. It's in the hands of the courts so we all know that EA ist kaput but not much else. I have been on other sites and forums and it's pretty much the same as here. Other than some still bragging about their wonderful and no longer available EA attachments, there isn't much to say.
   / Status of Everything Attachments #1,306
Furthermore, there is another thread
specifically for people who had unresolved issues looking for more solid information about EA.
I believe the latest is that they are kaput.
   / Status of Everything Attachments #1,307
Meh, I suspect the first 100 pages of the thread covered the pertinent issues, even before that it was quite repetitive. A little topic deviation is expected on any forum, but I digress as I just added to it 😎
   / Status of Everything Attachments #1,309
Your right... I have nothing to add and unless I could do some gumshoe investigation I probably won't have anything original to add...
Never have I unsubscribed from a thread in 20 years at TBN but unsubscribing will remove the temptation...
   / Status of Everything Attachments #1,310
Back to topic at hand, SOCKS. Ok, is it sock sock, shoe shoe, OR Sock shoe, sock shoe?
   / Status of Everything Attachments #1,311
I've been using debit cards since they came out (perfect credit BTW, so certainly not a case of "marginal credit" as some other poster inanely commented); Also have several CC's that get paid off after each purchase.
I've had my debit and CC numbers skimmed / scammed multiple times as I travel a lot and you'd be surprised how easily someone can get your card info at a gas station.
In any event, I've actually had more proactive protection and action from the debit card than the CCs, I'll get fraud alerts very quickly and its the same process from both when they catch it and correct, send a new card, etc.
To your point regarding overdraft fees, it's never happened to me in over 25 years, they automatically refund the fraudulent charges and I've never paid an overdraft fee of any kind.
Perhaps it all boils down to which bank you use & their policies, but my wife and I consistently use our debit cards without fear.
Sure, for big purchases, we use our CCs for the added insurances they provide along with the points / miles that we rack up, but for day-to-day items, I much prefer the convenience of tapping / swiping a debit card than carrying around stacks of cash. If my wallet gets swiped, I touch a button and my cards are frozen, but say goodbye to the cash....
For an online purchase of an implement, CC all day long
The tap of the chip on my credit card is much more secure from skimming than anything else at a gas pump or in the store.
For online purchases, I use the CapitalOne virtual cards which are a one-time throw away number or, are time-limited before they expire depending on the merchant.
Virtual cards prevent most fraud. I'm not sure how someone got it but, the virtual card number someone tried using at Sonic several states away to buy a drink was flagged as expired every time it was attempted!!! Yea!
This generally means I don't have to go through the fraud process to get my money and the thieves got nothing!
Whether the credit or debit card company makes me whole or not, the criminals still got the money! My focus is on denying the money in the first place!
I still maintain that buyer protection and fraud protection on credit cards is much better than debit cards. This is enforced in law as well. If your bank protects your debit card the same, great for you but, that is not true for everyone and every bank.
And regarding secured credit cards and debit cards in general, it isn't only about people that are poorly banked or are struggling financially, most people use credit cards for the perks they get in addition to the better protections enforced in law. My credit card also does not open up my entire estate at the bank to fraud like a debit card does.
Then there are billing errors from public utilities. Do you really want a $300K water bill hitting your debit card/bank or, would you prefer to have your credit card company reject it for throwing you over your limit? Didn't happen to me but, a distant friend had their home equity loan, savings, checking, and various investments all linked together for convenience at their bank. They auto "debited" of all their utilities each month. A programming error tied their home account to that of a Golf Course. When the >$300,000 water bill hit, their home equity was drained, their savings were gone, etc. 6 weeks later the error was proven and the money was refunded but, they missed a house payment, were late on other utilities, missed car payments, etc. Convenience though!?!
My normal electric bill is ~$300 each month. This month was >$500. My credit card said it was declined and I logged into my utility account to see what happened. Turns out a rate change and a cold snap added ~$200 to my bill. At that point, I paid it and adjusted billing expectations for my credit card.
   / Status of Everything Attachments #1,312
It depends on what kind of mood I'm in.
Here's another question. Do you stand on one leg while dressing the other foot or do you sit down?
   / Status of Everything Attachments #1,313
Buyer protection on a debit card is much weaker than on a credit card. Plus, on a debit card, the money comes straight out of your account often leading to overdraft fees and other issues if the card is misused.
Very true, but the two times I had my debit card hacked, the bank restored the money. I also don’t keep more than $1k in that checking account. I like just keeping what I can spend in that checking account and paying bills and investments in other accounts. Savings and other investments don’t have a debit card linked.
   / Status of Everything Attachments #1,314
I've already stated the facts as I know them to be true in my actual, hands-on, experiences; Thus far, you've not changed my mind as there are many unknown variables at play with your examples.
I also stated that I agreed that CCs provide more insurances & perks. So not sure why that's being re-hashed.
We can certainly go around and around in circles with hypothetical and assumed situations, but I choose to substantiate my stance with what I have personally encountered thus far.
So rather than dive into an endless abyss of hypotheticals, we can surmise that I'll do me and you do you.
Best regards!
   / Status of Everything Attachments #1,315
Similar for me; I've had my debit card skimmed at least 6 or 7 times, in every case, they caught it before I did and put a temp hold on my account until I called in. In every case, they removed the fraudulent charges the same day and eventhough my larger savings account was attached to the debit, I've yet to see that affected.
Maybe I'm just lucky, but I also maintain several other accounts with liquid assets that are ready in a moments notice should I ever run into a situation. I just have no reason to be scared about debit card fraud based upon my lengthy experiences.
Again, for online purchases of implements with a potential delay in shipping, I use a CC all day long.
   / Status of Everything Attachments #1,317
I'm still not sure why you're discussing credit vs debit cards, when the thread is about socks.
Or shoes.
Or proper electrical wiring.
Or something like that.
True, back to more important sub-topics .... and go:
   / Status of Everything Attachments #1,318
Best regards!
I'm not disagreeing with your experience but, for a wider audience I think it is important to note that not everyone has the same experience with their bank or credit card vendor.
   / Status of Everything Attachments #1,319
Or shoes.
Weren’t you commenting awhile ago about thread drift being normal?
   / Status of Everything Attachments #1,320
Agreed, nor would I think my specific experiences serve as a baseline; That said, I also believe that some folks have a tendency to obfuscate actual facts and simply post up unsubstantiated "feelings" on the topic without having any real, actual, experience ... that's all. Not saying that was the case in your response, but it occurred up-thread and I couldn't help but comment. 😉
2007 JLG E400 AJP TELESCOPIC/SCISSORING MANLIFT (A52707)
2007 JLG E400 AJP...
2011 DRAGON 130BBL VAC TRAILER (A58214)
2011 DRAGON 130BBL...
KIOTI SL7504-PL SKID STEER (A60429)
KIOTI SL7504-PL...
2006 Nissan Frontier Ext. Cab Pickup Truck (A59230)
2006 Nissan...
Informational Lot - Shipping (A61307)
Informational Lot...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
